لود نشدن عکس ها
hossein44
یه برنامه درست کردم که عکس و متن باهمه
موقعی که روی گوشی برنامه را اجرا میکنم وقتی روی لیست ویو کلیک میکنم که بره به قسمت مطالب این ارورا میده
اینم سورس قسمت مطلبم هست
#Region  Activity Attributes
	#FullScreen: true
	#IncludeTitle: false
#End Region
Dim label1 As Label
	Dim i1 As PhoneIntents
	Dim intent1 As Intent
	Dim list1 As List
	Private Button1 As Button
	Private Button2 As Button
	Private Button12 As Button
	Private Button11 As Button
	Private Button5 As Button
	Private Button4 As Button
	Activity.LoadLayout("layout2")
	If File.Exists(File.DirInternal,"bargh.db")=False Then
	File.Copy(File.DirAssets,"bargh.db",File.DirInternal,"bargh.db")
If main2.sql1.IsInitialized=False Then
	main2.sql1.Initialize(File.DirInternal,"bargh.db",False)
Dim cur As Cursor
cur=main2.sql1.ExecQuery("SELECT * FROM bargh1 WHERE id="&main2.fasl)
cur.Position=0
If cur.GetInt("fav")=0 Then
	Dim Ba As BitmapDrawable
	Ba.Initialize(LoadBitmap(File.DirAssets,"fav.png"))
	Button2.Background=Ba
 	Ba.Initialize(LoadBitmap(File.DirAssets,"fav2.png"))
Dim h As Int
For i = 0 To 13
	If cur.GetString("matn"&i) <> Null Then
		label1.Initialize("Label1")
		label1.Text=cur.GetString("matn"&i)
		label1.TextColor=Colors.White
		label1.TextSize=20
		label1.Gravity=Gravity.RIGHT
		ScrollView1.Panel.AddView(label1,0,h+2%y,ScrollView1.Width-10,ScrollView1.Height)
		Dim su As StringUtils
		label1.Height=su.MeasureMultilineTextHeight(label1,label1.Text)+10
		h=h+su.MeasureMultilineTextHeight(label1,label1.Text)+30
		ScrollView1.Panel.Height=h
	If cur.GetString("aks"&i) <> Null Then
		Dim ImageView1 As ImageView
		ImageView1.Initialize("imageview")
		ImageView1.Tag=cur.GetString("aks"&i)
		ScrollView1.Panel.AddView(ImageView1,0,h,ScrollView1.Width,ScrollView1.Height)
		ImageView1.Bitmap=Main.bitmap1(i)
		If Main.bitmap1(i).width > 100%x Then
			ImageView1.Width=100%x
			ImageView1.Height=(ImageView1.Width/Main.bitmap1(i).width)*Main.bitmap1(i).Height
			ImageView1.Gravity=Gravity.FILL
				ImageView1.Width=Main.bitmap1(i).Width
				ImageView1.Height=Main.bitmap1(i).Height
				ImageView1.Left=(100%x-ImageView1.Width)/2
	h=h+ImageView1.Height+30
Sub Activity_Resume
Sub Button1_Click
	StartActivity(main2)
	Activity.Finish
Sub Button2_Click
	Dim cur As Cursor
    For i=0 To cur.rowcount-1
    cur.position=i
    Dim f As Int
    f = cur.GetInt("fav")
    If f = 1 Then
  main2.SQL1.ExecNonQuery("UPDATE bargh1 SET fav = 0 WHERE id = "&cur.GetInt("id"))
	Dim bb As BitmapDrawable
	bb.Initialize(LoadBitmap(File.DirAssets,"fav.png"))
	Button2.Background=bb
	ToastMessageShow("از لیست علاقه مندی ها حذف شد",False)
     main2.SQL1.ExecNonQuery("UPDATE bargh1 SET fav = 1 WHERE id = "&cur.GetInt("id"))
	bb.Initialize(LoadBitmap(File.DirAssets,"fav2.png"))
	ToastMessageShow("به لیست علاقه مندی ها اضافه شد",False)
cur.close
Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
کسی میدونه مشکل از چیه؟
شما بیایید Dim Ba As BitmapDrawable رو فقط یک بار توی Sub Globals تعریف کنید
اگر باز خطا داد لطفا برنامه رو در حالت Debug اجرا کنید ببینید دقیقا خطا از کدوم خط گرفته میشه؟
منتظر پاسخ نتیجه هستم
توی حالت دیباگ که قرار دادم توی این خط گیر میده
متوجه این خط نشده بودم
ببینید خطا کاملا مشخصه اصلا
شما دارید یک عکس رو به ImageView میدید که توی یک Activity دیگه قرار داره که اصلا الان عملا اسمش مشخص نیست  :wacko1:
پیشنهاد من اینه یک String توی Process Globals تعریف کنید و آدرس همون Bitmap i رو از توی Main بردارید و توی همین خط کد اون رو LoadBitmap کنید  :malih:
خوب الان توی قسمت main من این کدا توی Process_Globals  تعریف کردم
Dim bitmap1(14) As Bitmap
متوجه منظور بنده نشدید...
منظور بنده این است که آدرس رو زمانی که میخواهید به Activity جدید برید به یک String بدید و اون عکس رو توسط همون String توی Activity جدیدتون LoadBitmap کنید
