درخواست سورس جستجو در مولتی پنل
alivoll
#Region  Activity Attributes
	#FullScreen: true
	#IncludeTitle: false
#End Region
Sub Process_Globals
	'Dim ht As HttpJob
	Dim cur1 As Cursor
	Dim sql1 As SQL
	Dim titr As String
	Private EditText1 As EditText
	Private Panel1 As Panel
	Private Label1 As Label
	Dim stop As Int = 3%y
	Private Label2 As Label
	Private Label3 As Label
	Private ImageView1 As ImageView
	Private Label4 As Label
	'Private ImageView2 As ImageView
	Dim p As Panel
	Private img2 As Button
	Private ImageViewfgfd As ImageView
	'Private asdghh As Panel
	Private titr12345 As Label
	Activity.LoadLayout("search")
	   	If File.Exists(File.DirInternal,"shopcar1.db") = False Then
	File.Copy(File.DirAssets,"shopcar1.db" , File.DirInternal,"shopcar1.db")
	sql1.Initialize(File.DirInternal,"shopcar1.db" , True)
	cur1 = sql1.ExecQuery("SELECT * FROM time ORDER BY id DESC")
	For i = 0 To cur1.RowCount -1
		cur1.Position = i
		Dim p As Panel
		p.Initialize("p")
		ScrollView1.Panel.AddView(p,0,stop,100%x , 100%y)
		stop = stop + 23%y
		p.LoadLayout("main")
		Label1.Text = cur1.GetString("titr")
		Label1.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
		Label2.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
		Label3.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
		Label4.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
		titr12345.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
		Label2.Text = cur1.GetString("loc")
		Label3.Text = cur1.GetString("time")
		Label4.Text = cur1.GetString("money")
		Panel1.tag = cur1.getstring("id")
		ImageView1.tag = cur1.GetString("ax")
		Dim caso As Picasso
		caso.Initialize
		caso.LoadUrl(cur1.GetString("ax")).IntoImageView(ImageView1)
		ScrollView1.Panel.Height = stop
		ImageViewfgfd.Visible=False
		img2.Visible=False
		titr12345.Text = cur1.GetString("money")
Sub Activity_Resume
	ScrollView1.Panel.RemoveAllViews
	Dim cur As Cursor
	cur=asli.SQL1.ExecQuery("SELECT * FROM time WHERE titr LIKE '%"&EditText1.Text&"%'")
	For i = 0 To cur.RowCount-1
    cur.Position=i
در در 1395/07/05, 23:05:45، dftbayat گفته است :
قبلا بسیار بحث شده سرچ کنید
در در 1395/07/07, 12:18:47، مهدی ایزدی گفته است :
لطفا کدهایی که خودتون برای سرچ قرار دادید رو بزارید تا  رفع عیب بشه
ارسال کردم بفرما
دوست عزیز ببینید
شما کار با خود MultiPanel رو که بلد هستید
ما واسه کوئری میاییم مثلا میگیم: select * from tbl
درسته ؟
خب واسه سرچ هم شما همون کدها رو عینا بیایید پیاده کنید... منتهی بگید: select * from tbl where name = izadi
قبل از add کردن ابزارها هم scrollview1.Panel.RemoveAllViews کنید و همچنین scrollview1.panel.height = 0 کنید
که اگر چندین بار پشت سر هم سرچ کردید دچار مشکل نشید
همین کارهایی که گفتم رو انجام بدید... هرجا مشکل خوردید بگید !
این کد شماست :
	Dim cur As Cursor
    cur.Position=i
خب درست رفتید تا اینجا
حلقتون ولی خالیه چرا ؟
همون کدهایی که توی حلقه ی Activity Create به کار بردید برای اینجا هم به کار ببرید. فکر نکنم مشکلی وجود داشته باشه
اطلاع بدید نتیجه رو
	#FullScreen: true
#End Region
Sub Process_Globals
	Dim cur1 As Cursor
	Dim sql1 As SQL
	Dim titr As String
'	Dim stop As Int = 3%y
	'Dim ht As HttpJob
	Private text As Label
	Private balck1 As Panel
'	Private black2 As Label
	Private black23 As Label
	Private black24 As Label
	Dim p As Panel
	Private asdf As Panel
	Activity.LoadLayout("scrolllayout")
    Dim inter As AriaLib
 	If inter.TestInterntConnection = True Then
	text.Text=("نمایشگاه خودرو")
	text.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
	asdf.Visible=True
	Activity.LoadLayout("black")
	balck1.Visible=True
	black23.Text=("عدم دسترسی به اینترنت و شبکه جهانی")
	black23.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
	black24.Text=("برای خروج صفحه را لمس کنید")
	black24.Typeface=Typeface.LoadFromAssets("iran_sans.ttf")
ProgressDialogShow("در حال ارتباط با سرور")
Dim ht As HttpJob
ht.Initialize("update",Me)
ht.Download("http://appcar.xzn.ir/shopcar1.db")
Sub Activity_Resume
Sub Panel1_Click
  Dim pan As Panel
  pan=Sender
  titr=pan.Tag
'  Log(pan.tag)
 StartActivity(ali)
 Activity.Finish
Sub balck1_Click
	balck1.Visible=False
	black23.Visible=False
	black24.Visible=False
	ExitApplication
	Activity.Finish
Sub JobDone(Job As HttpJob)
	ProgressDialogHide
	'ScrollView1.Panel.RemoveAllViews
	 If Job.Success Then
  If Job.JobName = "update" Then
   Dim ou As OutputStream
   File.Delete(File.DirInternal,"shopcar1.db")
   ou = File.OpenOutput(File.DirInternal,"shopcar1.db",False)
   File.Copy2(Job.GetInputStream,ou)
   ou.Close
 	asdf.Visible=False
'	Return
		cur1.Position = i
		Dim p As Panel
		p.Initialize("p")
		stop = stop + 23%y
		Dim caso As Picasso
		caso.Initialize
		img2.Visible=False
Sub img2_Click
	Dim ht As HttpJob
Sub img1_Click
StartActivity(search)
خب برای این قسمت میخوام جستجو بزارم میشه یه سورس جستجو بسازی ازش من هر چقدر کردم نشد
در 15 دقیقه قبل، alivoll گفته است :
