hojjatborohan 56 ارسال شده در 11 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 11 اردیبهشت، 2018 دوستان من میخوام از اسکنر استفاده کنم این اررور رو نشون میده B4A Version: 7.80 Parsing code. (0.00s) Compiling code. (0.18s) Compiling layouts code. (0.05s) Organizing libraries. (0.00s) Generating R file. (0.07s) Compiling debugger engine code. (0.71s) Compiling generated Java code. (1.19s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/B4AApplication; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Bit; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$10; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$11; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$11$1; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$12; Uncaught translation error: java.lang.IllegalArgumentException: already added: Lanywheresoftware/b4a/keywords/Common$13; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:689) at com.android.dx.command.dexer.Main.runMonoDex(Main.java:313) at com.android.dx.command.dexer.Main.run(Main.java:279) at com.android.dx.command.dexer.Main.main(Main.java:247) at com.android.dx.command.Main.main(Main.java:106) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:681) ... 4 more لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
محمدرضا شاهپیری 5,618 ارسال شده در 11 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 11 اردیبهشت، 2018 عزیز عنوان سوالتون رو درست انتخاب کنید. از چه کتابخونه ای استفاده کردین ؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 این کنابخانه zxScannerLiveView 612b4aZXscannerLiveView 71zxScannerLiveViewLibFiles(1) لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 12 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 سلام این فایل رو در بخش کتابخانه های بیسیک فور کپی کنید ببینید مشکلتون حل میشه ؟ البته غیراز دوتا کتابخانه Core ورژن 7.28 و کتابخانه ZXscannerLiveView چیز دیگه ای فعال نباشه . این سورس شما ، برای من که توی جنی موشن بدون خطا کارمیکنه core-3.1.0 لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 دارمش این کتابخانه رو لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 12 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 ورژن Core همینه که توی پست قبلی گفتم؟ کتابخانه ی دیگه ای براتون فعاله؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 اقا دمت گرم اومد بالا اما اسکنرش سیاه کار نمیکنه ! لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 12 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 الان توی گوشی هم امتحان کردم وصفحه خیلی طبیعی هست وتصاویر دوربین رو نمایش میده شایدتوی شبیه ساز امتحانش میکنیدکه خب طبیعیه سیاه میاددیگه لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 الان دوربین هم اومد بالا اما متاسفانه QR نمیخونه و فقط بارکد میخونه . شما همچین برنامه ای میشناشید که QR بخونه ؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 12 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 ببینید این کتابخانه ها QR یا بارکد دوبعدی به دردتان میخوره؟(البته بهتره عنوان پست اولتان هم خطا در سورس بارکدخوان باشه که واضحتربشه ) QRcode (lib only) 1.03 936ABZxing یه تصویرهم برای کسانی بعدا این مطالبو میخونند و با QR اشنایی ندارند اینجا میگذارم : لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 این و دارم . ولی میخوام به صورت ویو باشه و به فرمم اضافه بشه لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
نورنما 613 ارسال شده در 12 اردیبهشت، 2018 اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 اینم کتابخانه سوم ببینیداین به دردتان میخوره ؟ : PersonalisedQRcodes PersonalisedQRcodes_2 منبع: Android Example - Create Personalised QR Codes | B4X Community - Android, iOS, desktop, server and IoT programming tools اینم کتابخانه چهارمی: JHSQRCODEREADV4 qrcodev21ehm6 qrcodev4elm5 JHS_QR_FP JHS_QR_FP_1 منبع: Android Example - QR Code - Reverse Engineering a QR Code | B4X Community - Android, iOS, desktop, server and IoT programming tools ______________ من همین چند تا کتابخونه رو که فرستادم دارم چندتا کتابخانه دیگه هم هست که در سایت مرجع هست ، مطالعه بفرمایید اگه اونا به دردتان بخوره ، پی اونها باشید 5- QREader B4A Library - QREader - Scan 1D and 2D barcodes (QR Code, PDF 417, Aztec, etc) | B4X Community - Android, iOS, desktop, server and IoT programming tools 6- JHS BARCODES V102 B4A Library - QR Code Library | B4X Community - Android, iOS, desktop, server and IoT programming tools ______ اینها هم کتابخانه مرتبط با QR (گفتم بی ربط نیست وبعدا شاید به درد افرادی بخوره اینجا فرستادمشون) QR_CodeFormatInformation ReedSolomonGeneratorPolynomialV2 QR_CodeVersionInformation B4A Library - Wrapper to zxing QRCode, EAN-13 & EAN-8 Generator | B4X Community - Android, iOS, desktop, server and IoT programming tools ________________ PasswordQRcodes b4aPasswordProtectedQRCodeReaderView AndroidLibFiles JavaObject 7-->اینم همینطور : QRCodeReaderViewLibFiles منبع: Android Example - Password Protected QR Codes - Creating and Scanning Password Protected QR Codes | B4X Community - Android, iOS, desktop, server and IoT programming tools ____________ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56 ارسال شده در 12 اردیبهشت، 2018 سازنده اشتراک گذاری ارسال شده در 12 اردیبهشت، 2018 B4A Library - QREader - Scan 1D and 2D barcodes (QR Code, PDF 417, Aztec, etc) | B4X Community - Android, iOS, desktop, server and IoT programming tools احتمالا این بکارم بیاد اما نمیتونم دانلودش کنم من viP ندارم لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
hojjatborohan 56
