من از کتابخونه SD Floating StandOut Library و مثال خودش استفاده کردم. ولی موقعه استارت این ارورر میده:
standout_service_create (java line: 507)
java.lang.RuntimeException: Cannot change properties after call to SetInfo. Initialize the notification again.
این کدهای مثال یک کنابخونه :
Activity.LoadLayout("main")
FloatingStandOut.PathImage=File.DirAssets
FloatingStandOut.NameFileImage="image2.png"
FloatingStandOut.X=50%x
FloatingStandOut.Y=50%y
FloatingStandOut.SetStartActivity(True,True,False)
FloatingStandOut.SetStopFloating(True,True,True)
Sub Activity_Resume
FloatingStandOut.Stop
FloatingStandOut.Start(Me)
Sub Button1_Click
Activity.Finish
اینم کدهای مثال 2 خود کتابخونه
FloatingStandOut.NameFileImage="image1.png"
FloatingStandOut.SetEvent("FS")
FloatingStandOut.SetStartActivity(True,False,False)
FloatingStandOut.SetStopFloating(False,False,True)
' FloatingStandOut.Start(Me)
Sub Activity_Resume
Sub Activity_Touch (Action As Int, X As Float, Y As Float)
Activity.Finish
Sub ButtonStart_Click
Sub ButtonStop_Click
Sub Button1_Click
Sub Button2_Click
Sub Button3_Click
FloatingStandOut.NameFileImage="image3.png"
Sub Button4_Click
FloatingStandOut.NameFileImage="image4.png"
Sub FS_OnClick(X As Int,Y As Int)
'Label.Text="Single Tap"
PanelMain.Visible=False
PanelMenu.Visible=True
PanelMenu.Left=FloatingStandOut.X-(PanelMenu.Width-FloatingStandOut.WidthImage)/2
PanelMenu.top=FloatingStandOut.y-(PanelMenu.Height-FloatingStandOut.HeightImage)/2
StartActivity(Me)
Sub FS_OnDoubleClick(X As Int,Y As Int)
Label.Text="Double Tap"
Sub FS_OnLongClick(X As Int,Y As Int)
Label.Text="Long Tap"
Sub FS_OnMove(X As Int,Y As Int)
If PanelMenu.Visible Then
Sub Button_Click
PanelMain.Visible=True
PanelMenu.Visible=False
Sub PanelMain_Touch (Action As Int, X As Float, Y As Float)
علیرضا _امیراحمدی 0
ممنون میشم کسی راهنمایی کنه
