سلام به همه دوستان عزیز من با استفاده از کد زیر صفحه تنظیمات برنامه رو ساختم :
#Region Activity Attributes
#FullScreen: True
#IncludeTitle: False
#End Region
Dim Font As String
Dim Size As Int
Dim Color As ColorPickerDialog
Private btncolor As Button
Private BtnSave As Button
Private FontSize As SeekBar
Private FontType As Spinner
Private Label1 As Label
Private Label2 As Label
Private Label3 As Label
Private Label4 As Label
Private Label5 As Label
Private OpenList As Button
Activity.LoadLayout("frm5")
FontType.AddAll(Array As String("BYEKAN","BKOODAK","BMITRA","MJLINER","BTITR"))
Label4.TextSize=18
FontSize.Value = Size
'Label1.Typeface=Typeface.LoadFromAssets("BYEKAN.TTF")
'Label2.Typeface=Typeface.LoadFromAssets("BYEKAN.TTF")
'Label3.Typeface=Typeface.LoadFromAssets("BYEKAN.TTF")
Label4.Typeface=Typeface.LoadFromAssets("Yekan.ttf")
Label5.Typeface=Typeface.LoadFromAssets("Yekan.ttf")
Sub FontType_ItemClick (Position As Int, Value As Object)
If Position = 0 Then
If Position = 1 Then
Label4.Typeface=Typeface.LoadFromAssets("Koodak.ttf")
If Position = 2 Then
Label4.Typeface=Typeface.LoadFromAssets("Mitra.ttf")
If Position = 3 Then
Label4.Typeface=Typeface.LoadFromAssets("Linerscreen.ttf")
If Position = 4 Then
Label4.Typeface=Typeface.LoadFromAssets("Btitrbd.ttf")
Sub FontSize_ValueChanged (Value As Int, UserChanged As Boolean)
Label4.TextSize=Value
Label5.Text=Value
Sub btncolor_Click
Color.Show("کلکسیون رنگ ها","انتخاب","انصراف","",LoadBitmap(File.DirAssets,"000.png"))
'btncolor.Typeface=Typeface.LoadFromAssets("yekan.ttf")
code.saveData("setting.txt","FontColor",Color.RGB)
Label4.TextColor=Color.RGB
'btncolor.TextColor=Color.RGB
Sub BtnSave_Click
Font=FontType.SelectedItem
Size=FontSize.Value
Dim list1 As List
list1.Initialize
list1.Add(Font)
list1.Add(Size)
File.WriteList(File.DirInternal,"Settings.stg",list1)
ToastMessageShow("تنظیمات با موفقیت اعمال شد",False)
StartActivity(Menu)
Activity.Finish
Sub OpenList_Click
StartActivity(Menu)
Activity.Finish
و با استفاده از کد زیر تنظیمات رو در صفحه مطالب اعمال کردم :
label1.TextColor=Colors.Black
If File.Exists(File.DirInternal,"Settings.stg")=True Then
Dim list1 As List
list1=File.ReadList(File.DirInternal,"Settings.stg")
Setting.font=list1.Get(0)
Setting.size=list1.Get(1)
Dim a As String
a = code.getData("setting.txt","FontColor")
label1.TextColor = code.getData("setting.txt","FontColor")
Setting.font="BYEKAN"
Setting.size=25
label1.Typeface=Typeface.LoadFromAssets(Setting.font &".ttf")
label1.TextSize=Setting.size
و با استفاده از کد زیر یک code module با نام code ساختم:
Sub saveData(sFilename As String,sKey As String,sValue As String)
Dim m1 As Map
m1.Initialize
If File.Exists(File.DirInternal,sFilename) = True Then
m1 = File.ReadMap(File.DirInternal,sFilename)
m1.Put(sKey,sValue)
File.WriteMap(File.DirInternal,sFilename,m1)
Sub getData(sFilename As String,sKey As String) As String
Dim m1 As Map
m1.Initialize
Return ""
If m1.ContainsKey(sKey) = True Then
Return m1.get(sKey)
Return ""
و این هم یک عکس از پوشه files برنامه من هست :
ولی وقتی وارد صفحه مطالب می شم به این خط در کد صفحه مطالب گیر می ده هر کاری کردم نتونستم مشکل رو رفع کنم و به همین خاطر مزاحم شما عزیزان شدم لطفا یک پاسخ کامل بدید که من باید چی کار کنم یا اگه راه دیگه ای رو پیشنهاد دارید بگید و کامل توضیح بدید بسیار ممنونم
MahdiHD 1,748
23 پاسخ به این سوال تاکنون داده شده است
