Dim fara As Farakhani
Dim p As MediaPlayer
Private btn1 As Button
Private listahang As ListView
Dim ht As HttpJob
Dim rowCount As Int
Dim ht2 As HttpJob
Private Button1 As Button
Activity.LoadLayout("listahang")
fara.initialize("db.db","tbl_music",True)
fara.SingleLineTitr(listahang,"name_music","id")
p.Initialize2("p")
If File.Exists(File.DirInternal,"db.db") = False Then
File.copy(File.DirAssets,"db.db",File.DirInternal,"db.db")
If sql.IsInitialized = False Then
sql.Initialize(File.DirInternal,"db.db",True)
showlist
ht.Initialize("job1",Me)
ht2.Initialize("job2",Me)
Sub Activity_Resume
p.Pause
Sub listahang_ItemClick (Position As Int, Value As Object)
Dim name_file As String
name_file = fara.FarakhaniString("id",Value,"name_file")
p.Load(File.DirAssets,name_file)
p.Play
Sub Button1_Click
p.Pause
الان من دیتابیس انلاینمو راه انداختم
میخوام کاربر وقتی روی اهنگ کلیک میکنه اهنگ دانلود بشه وقتی p as mediaplayerstream میزارم نمیزاره که کد (p.Load(File.DirAssets,name_file رو بنویسم و کلا ارور میده اما در حالت p as mediaplayer هیچ اروری نیست الان من میخوام که تو دیتبیسم لینک دانلود اهنگو بدم و بعدش پخش بشه
Cna 5
سلام دوستان من یه کد نوشتم که اینه
Dim fara As Farakhani Dim p As MediaPlayer Private btn1 As Button Private listahang As ListView Dim ht As HttpJob Dim rowCount As Int Dim ht2 As HttpJob Private Button1 As Button End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("listahang") fara.initialize("db.db","tbl_music",True) fara.SingleLineTitr(listahang,"name_music","id") p.Initialize2("p") If File.Exists(File.DirInternal,"db.db") = False Then File.copy(File.DirAssets,"db.db",File.DirInternal,"db.db") End If If sql.IsInitialized = False Then sql.Initialize(File.DirInternal,"db.db",True) End If showlist ht.Initialize("job1",Me) ht2.Initialize("job2",Me) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) p.Pause End Sub Sub listahang_ItemClick (Position As Int, Value As Object) Dim name_file As String name_file = fara.FarakhaniString("id",Value,"name_file") p.Load(File.DirAssets,name_file) p.Play End Sub Sub Button1_Click p.Pause End Subالان من دیتابیس انلاینمو راه انداختممیخوام کاربر وقتی روی اهنگ کلیک میکنه اهنگ دانلود بشه وقتی p as mediaplayerstream میزارم نمیزاره که کد (p.Load(File.DirAssets,name_file رو بنویسم و کلا ارور میده اما در حالت p as mediaplayer هیچ اروری نیست الان من میخوام که تو دیتبیسم لینک دانلود اهنگو بدم و بعدش پخش بشه
ممنون میشم کمک کنید
