دارم برنامه ای برای ایجاد کتاب می نویسم. قسمتی از برنامم ارور میده ولی نمیدونم مشکلش کجاست.
ممنون میشم که کمکم کنید
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: False
#End Region
Dim blcatalog As Boolean
Private lblcatalog As Label
Private titrHeader1 As Label
Private ScrollView11 As ScrollView
If blcatalog = True Then
titrHeader1.text = "جلسات آموزشی "
titrHeader1.Text = "علاقمندی ها"
Dim top As Int
top = 0
Dim a1() As String
a1= Array As String("جلسه 1","جلسه 2","جلسه 3","جلسه 4")
a1= Array As String("جلسه 1","جلسه 4")
For i = 0 To a1.Length-1
Dim p1 As Panel
p1.Initialize("")
ScrollView11.Panel.AddView(p1,0,top,90%x,60dip)
p1.LoadLayout("frmTempelet")
lblcatalog.Tag = a1(i)
lblcatalog.Text = a1(i)
top = top + 60dip
Sub Activity_Resume
Sub activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
Activity.Finish
Return True
Sub lblcatalog_Click
Dim v1 As Label
v1 = Sender
matn.sTitle = v1.Tag
StartActivity(matn)
به این دو خط گیر میده
Private titrHeader1 As Label Private ScrollView11 As ScrollView
web1001 4
با سلام
#Region Activity Attributes #FullScreen: False #IncludeTitle: False #End Region Sub Process_Globals Dim blcatalog As Boolean End Sub Sub Globals Private lblcatalog As Label Private titrHeader1 As Label Private ScrollView11 As ScrollView End Sub Sub Activity_Create(FirstTime As Boolean) If blcatalog = True Then titrHeader1.text = "جلسات آموزشی " Else titrHeader1.Text = "علاقمندی ها" End If Dim top As Int top = 0 Dim a1() As String If blcatalog = True Then a1= Array As String("جلسه 1","جلسه 2","جلسه 3","جلسه 4") Else a1= Array As String("جلسه 1","جلسه 4") End If For i = 0 To a1.Length-1 Dim p1 As Panel p1.Initialize("") ScrollView11.Panel.AddView(p1,0,top,90%x,60dip) p1.LoadLayout("frmTempelet") lblcatalog.Tag = a1(i) lblcatalog.Text = a1(i) top = top + 60dip Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event If KeyCode = KeyCodes.KEYCODE_BACK Then Activity.Finish Return True End If End Sub Sub lblcatalog_Click Dim v1 As Label v1 = Sender matn.sTitle = v1.Tag StartActivity(matn) End Subبه این دو خط گیر میده
