من این کدها رو نوشتم ولی اسکرول نمیشه یعنی باید 10 بار دست بکشم تا شاید یه کم بیاد پایین
Sub add8(username1 As String, name1 As String , type1 As String)
Try
Dim ms01 As MSCardView
ms01.Initialize("MS01")
ms01.Elevation=2dip
ms01.MaxElevation=2dip
ms01.Radius=2dip
sv_fav.Panel.AddView(ms01,2%x,offsetY1,96%x,150dip)
Dim lbonvan As Button
lbonvan.Initialize("lbonvan")
lbonvan.Text=name1
lbonvan.TextColor=color1.md_blue_400
lbonvan.Color=Colors.Transparent
lbonvan.gravity = Gravity.RIGHT
lbonvan.TextSize=18
lbonvan.Typeface=Typeface.LoadFromAssets("yekan.ttf")
ms01.Panel.AddView(lbonvan,2%x,0,79%x,57dip)
Dim tempHeight As Float
Dim StringUtils1 As StringUtils
tempHeight = StringUtils1.MeasureMultilineTextHeight(lbonvan, lbonvan.text)
lbonvan.Height = tempHeight+30dip
Dim ImageView1 As ImageView
ImageView1.Initialize("ImageView1")
ImageView1.Gravity=Gravity.FILL
ImageView1.Bitmap=LoadBitmap(File.DirAssets,"no_image_avalabel.png")
ms01.Panel.AddView(ImageView1,80%x,5dip,42dip,39dip)
Dim dl_profile_img1 As String = "http://xxxxxx.ir/xxxx/xxxx/up/"&username1&".png"
Dim links As Map
links.Initialize
links.Put(ImageView1,dl_profile_img1)
CallSubDelayed2(ImageDownloader2, "Download", links)
CallSub(ImageDownloader2, "ActivityIsPaused")
ms01.Height =tempHeight+30dip
offsetY1=offsetY1+ms01.Height
sv_fav.Panel.Height=offsetY1+50dip
Catch
Log(LastException)
End Try
For Each v1 As View In Activity.GetAllViewsRecursive
If v1 Is Label Then
Dim lbl As Label
lbl = v1
lbl.Typeface = Typeface.LoadFromAssets("Yekan.ttf")
majid08 266
Sub add8(username1 As String, name1 As String , type1 As String) Try Dim ms01 As MSCardView ms01.Initialize("MS01") ms01.Elevation=2dip ms01.MaxElevation=2dip ms01.Radius=2dip sv_fav.Panel.AddView(ms01,2%x,offsetY1,96%x,150dip) '.................................................................................... Dim lbonvan As Button lbonvan.Initialize("lbonvan") lbonvan.Text=name1 lbonvan.TextColor=color1.md_blue_400 lbonvan.Color=Colors.Transparent lbonvan.gravity = Gravity.RIGHT lbonvan.TextSize=18 lbonvan.Typeface=Typeface.LoadFromAssets("yekan.ttf") ms01.Panel.AddView(lbonvan,2%x,0,79%x,57dip) Dim tempHeight As Float Dim StringUtils1 As StringUtils tempHeight = StringUtils1.MeasureMultilineTextHeight(lbonvan, lbonvan.text) lbonvan.Height = tempHeight+30dip '......................................................................................... Dim ImageView1 As ImageView ImageView1.Initialize("ImageView1") ImageView1.Gravity=Gravity.FILL ImageView1.Bitmap=LoadBitmap(File.DirAssets,"no_image_avalabel.png") ms01.Panel.AddView(ImageView1,80%x,5dip,42dip,39dip) '......................................................................................... Dim dl_profile_img1 As String = "http://xxxxxx.ir/xxxx/xxxx/up/"&username1&".png" Dim links As Map links.Initialize links.Put(ImageView1,dl_profile_img1) CallSubDelayed2(ImageDownloader2, "Download", links) CallSub(ImageDownloader2, "ActivityIsPaused") ms01.Height =tempHeight+30dip offsetY1=offsetY1+ms01.Height sv_fav.Panel.Height=offsetY1+50dip Catch Log(LastException) End Try For Each v1 As View In Activity.GetAllViewsRecursive If v1 Is Label Then Dim lbl As Label lbl = v1 lbl.Typeface = Typeface.LoadFromAssets("Yekan.ttf") End If Next End Subلینک ارسال
