#Region Project Attributes
#ApplicationLabel: MSMaterialDrawer
#VersionCode: 1
#VersionName:
#AdditionalRes: H:\materialdrawer\appcompat\res, android.support.v7.appcompat
#AdditionalRes: H:\materialdrawer\md-app\res
#AdditionalRes: H:\materialdrawer\md-lib\res
#End Region
سلام در هنگام کامپال کردن این ارور رو میده
Generating R file. Error
H:\materialdrawer\md-lib\res\values-v21\styles.xml:8: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:6: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:7: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:5: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:13: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:12: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:14: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:8: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:24: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:23: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:25: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:34: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:32: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:33: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:14: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:39: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:38: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:40: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:17: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:50: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:49: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:51: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:60: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:58: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:59: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:23: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:65: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:64: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:66: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v19\styles.xml:26: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:76: error: Error: No resource found that matches the given name: attr 'android:statusBarColor'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:75: error: Error: No resource found that matches the given name: attr 'android:windowDrawsSystemBarBackgrounds'.
H:\materialdrawer\md-lib\res\values-v21\styles.xml:77: error: Error: No resource found that matches the given name: attr 'android:windowTranslucentStatus'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:75: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:79: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.CloseMode'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:84: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.Overflow'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:25: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabView'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:29: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabView'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:33: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabText'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:37: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:65: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Title'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:69: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Subtitle'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:45: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Menu'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:49: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:53: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:57: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title.Inverse'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:61: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle.Inverse'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:195: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar.Horizontal'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:199: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:114: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:116: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner.Underlined'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:118: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:111: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.DropDownItem.Spinner'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:124: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:108: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView.DropDown'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:129: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListPopupWindow'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:141: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:146: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:132: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.PopupMenu'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:135: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.PopupMenu'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:149: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:153: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:157: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:161: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:167: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Title'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:171: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Subtitle'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:175: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.AutoCompleteTextView'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:94: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Toolbar.Button.Navigation'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:98: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:102: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:189: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.CompoundButton.CheckBox'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:191: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.CompoundButton.RadioButton'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:62: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:177: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.RatingBar'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:179: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:181: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Small'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:183: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Borderless'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:185: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Borderless.Colored'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:203: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.TextView.SpinnerItem'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:205: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.TextView.SpinnerItem'.
H:\materialdrawer\appcompat\res\values-v21\styles_base.xml:187: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ButtonBar'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:22: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display4'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:24: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display3'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display2'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:28: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display1'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:30: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Headline'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:32: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Title'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:34: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Subhead'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body2'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:38: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body1'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:40: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Caption'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:42: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Menu'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:60: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:46: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Inverse'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:48: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:50: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large.Inverse'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:52: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:54: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium.Inverse'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:56: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small'.
H:\materialdrawer\appcompat\res\values-v21\styles_base_text.xml:58: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small.Inverse'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:20: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:25: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:24: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:29: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentEnd'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:33: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:37: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:42: error: Error: No resource found that matches the given name: attr 'android:layout_toEndOf'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:41: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:47: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:52: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:51: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:56: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:60: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:64: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:65: error: Error: No resource found that matches the given name: attr 'android:textAlignment'.
H:\materialdrawer\appcompat\res\values-v17\styles_rtl.xml:69: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:34: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:158: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:162: error: Error: No resource found that matches the given name: attr 'android:colorButtonNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:160: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:161: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:159: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:156: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:157: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:169: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:173: error: Error: No resource found that matches the given name: attr 'android:colorButtonNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:171: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:172: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:170: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:167: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:168: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:87: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:91: error: Error: No resource found that matches the given name: attr 'android:colorButtonNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:89: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:90: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:88: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:85: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:86: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:136: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:140: error: Error: No resource found that matches the given name: attr 'android:colorButtonNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:138: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:139: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:137: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:134: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:135: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:144: error: Error: No resource found that matches the given name: attr 'android:windowElevation'.
H:\materialdrawer\appcompat\res\values-v21\themes_base.xml:148: error: Error: No resource found that matches the given name: attr 'android:windowElevation'.
bahman2012 13
