** Activity (main) Create, isFirst = true ** ~w:1004,main,22 ** Activity (main) Resume ** ** Activity (main) Pause, UserClosed = true ** ** Activity (menu) Create, isFirst = true ** ~w:1004,menu,19 menu_activity_create (B4A line: 30) r.RunStaticMethod("ir.adad.AdadB4APlugin", "cr java.lang.ClassNotFoundException: ir.adad.AdadB4APlugin at java.lang.Class.classForName(Native Method) at java.lang.Class.forName(Class.java:217) at java.lang.Class.forName(Class.java:172) at anywheresoftware.b4a.agraham.reflection.Reflection.RunStaticMethod(Reflection.java:906) at ir.mahdikafshgar.mohamad.menu._activity_create(menu.java:375) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:511) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:187) at ir.mahdikafshgar.mohamad.menu.afterFirstLayout(menu.java:100) at ir.mahdikafshgar.mohamad.menu.access$100(menu.java:17) at ir.mahdikafshgar.mohamad.menu$WaitForLayout.run(menu.java:78) at android.os.Handler.handleCallback(Handler.java:725) at android.os.Handler.dispatchMessage(Handler.java:92) at android.os.Looper.loop(Looper.java:137) at android.app.ActivityThread.main(ActivityThread.java:5041) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:511) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:793) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:560) at dalvik.system.NativeStart.main(Native Method) Caused by: java.lang.NoClassDefFoundError: ir/adad/AdadB4APlugin ... 20 more Caused by: java.lang.ClassNotFoundException: Didn't find class "ir.adad.AdadB4APlugin" on path: /data/app/ir.mahdikafshgar.mohamad-2.apk at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:65) at java.lang.ClassLoader.loadClass(ClassLoader.java:501) at java.lang.ClassLoader.loadClass(ClassLoader.java:461) ... 20 more
ali-akbar 1
~w:1004,main,22
~w:1004,menu,19
... 20 more
... 20 more
