#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim sql1 As SQL
Dim cur As Cursor
Dim timer1 As Timer
Private mn3 As Button
Private ex As Button
Private lv As ListView
Dim PanelWithSidebar As SlidingSidebar
Dim lv1 As ListView
Dim it As Boolean
Dim sec As Int
Dim ch As EditText
'Activity.LoadLayout("Layout1")
Activity.LoadLayout("menu")
'menu>>--------------------
Dim gd(2) As Int
gd(0) = Colors.White
gd(1) = Colors.LightGray
Dim gdContent As GradientDrawable
gdContent.Initialize("RIGHT_LEFT", gd)
Activity.Color = gd(0)
PanelWithSidebar.Initialize(Activity, 200dip, 1, 1, 200, 200)
PanelWithSidebar.ContentPanel.Background = gdContent
PanelWithSidebar.Sidebar.Background = PanelWithSidebar.LoadDrawable("jog_tab_bar_left_end_normal")
PanelWithSidebar.SetOnChangeListeners(Me, "Sidebar_onFullyOpen", "Sidebar_onFullyClosed", "Sidebar_onMove")
PanelWithSidebar.ContentPanel.LoadLayout("menu")
Dim r As Reflector
r.Target = PanelWithSidebar.Sidebar
r.RunMethod4("setPadding", Array As Object(0, 0, 0, 0), Array As String("java.lang.int", "java.lang.int", "java.lang.int", "java.lang.int"))
lv1.Initialize("lvMenu")
lv1.AddTwoLinesAndBitmap("صفحه اسلی","",LoadBitmap(File.DirAssets,"home.png"))
lv1.AddTwoLinesAndBitmap("فهرست","",LoadBitmap(File.DirAssets,"to.png"))
lv1.AddTwoLinesAndBitmap("علاقه مندی ها","",LoadBitmap(File.DirAssets,"f.png"))
lv1.AddTwoLinesAndBitmap("ارتباط با ما","",LoadBitmap(File.DirAssets,"co.png"))
lv1.AddTwoLinesAndBitmap("درباره ی ما","",LoadBitmap(File.DirAssets,"abo.png"))
lv1.AddTwoLinesAndBitmap("خروج","",LoadBitmap(File.DirAssets,"ex.png"))
lv1.Color = Colors.RGB(189, 139, 203)
lv1.ScrollingBackgroundColor = Colors.Transparent
Dim lbltxtsidebar As Label
lbltxtsidebar = lv1.TwoLinesAndBitmap.Label
lbltxtsidebar.left = lbltxtsidebar.Left - 90dip
lbltxtsidebar.Top=lbltxtsidebar.Top+15dip
lbltxtsidebar.TextColor=Colors.RGB(13, 10, 62)
lbltxtsidebar.TextSize = 15
myview(lbltxtsidebar,20,"yekan")
PanelWithSidebar.Sidebar.AddView(lv1, 2dip, 0, PanelWithSidebar.Sidebar.Width , PanelWithSidebar.Sidebar.Height - 40dip)
Dim bg1(2) As Int
bg1(0) = Colors.RGB(21, 42, 96)
bg1(1) = Colors.RGB(27, 54, 124)
PanelWithSidebar.Sidebar.Color=Colors.RGB(189, 139, 203)
PanelWithSidebar.EnableSwipeGesture(True, 40dip, 1)
lv.AddTwoLinesAndBitmap2("فهرست","فهرست",LoadBitmap(File.DirAssets,"to.png"),1)
lv.AddTwoLinesAndBitmap2("جستجو","جستجو",LoadBitmap(File.DirAssets,"ser.png"),2)
lv.AddTwoLinesAndBitmap2("علاقه مندی ","علاقه مندی",LoadBitmap(File.DirAssets,"f.png"),3)
lv.AddTwoLinesAndBitmap2("تنظیمات","تنظیمات",LoadBitmap(File.DirAssets,"set.png"),4)
lv.AddTwoLinesAndBitmap2("درباره ما","درباره ما",LoadBitmap(File.DirAssets,"abo.png"),5)
lv.TwoLinesAndBitmap.Label.Gravity = Gravity.CENTER
lv.TwoLinesAndBitmap.Label.TextColor = Colors.black
'data base>>-----------------
If File.Exists(File.DirInternal,"e1.db")=False Then
File.Copy(File.DirAssets,"e1.db",File.DirInternal,"e1.db")
If sql1.IsInitialized=False Then
sql1.Initialize(File.DirInternal,"e1.db",False)
cur = sql1.ExecQuery("SELECT * FROM tbl1")
ch.Text="1"
timer1.Initialize("timer1",3000)
Sub Activity_Resume
Sub myview(which As Label,fontsize As Int,fontname As String)
which.Typeface=Typeface.LoadFromAssets(fontname&".ttf")
which.TextColor=Colors.White
which.TextSize=fontsize
which.Gravity= Gravity.RIGHT
Sub lvMenu_ItemClick (Position As Int, Value As Object)
Log(Value)
Select Case Value
Case "صفحه اصلی"
StartActivity("menu")
Case "فهرست"
Case "علاقه مندی ها"
Case "ارتباط با ما"
Case "درباره ی ما"
Case "خروج"
Exit
End Select
PanelWithSidebar.CloseSidebar
If ch.Text="3" Then
Activity.removeallviews
ch.Text="1"
Return True
If ch.Text="2" Then
ch.Text="1"
Return True
If ch.Text="22" Then
ch.Text="1"
Return True
If ch.Text="222" Then
ch.Text="1"
Return True
If ch.Text="14" Then
ch.Text="1"
Return True
If ch.Text="1" Then
If it = False Then
timer1.Enabled = True
ToastMessageShow("برای خروج دوباره کلید بازگشت رو بزن",False)
it = True
Return True
Return False
Sub timer1_tick
If sec <= 3 Then
sec = sec+1
it = False
timer1.Enabled = False
mr-edris 186
سلام به همه ببخشید ببینید کد من ایرادی داره
بالا نمیاد
#Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim sql1 As SQL Dim cur As Cursor Dim timer1 As Timer End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private mn3 As Button Private ex As Button Private lv As ListView Dim PanelWithSidebar As SlidingSidebar Dim lv1 As ListView Dim it As Boolean Dim sec As Int Dim ch As EditText End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: 'Activity.LoadLayout("Layout1") Activity.LoadLayout("menu") 'menu>>-------------------- Dim gd(2) As Int gd(0) = Colors.White gd(1) = Colors.LightGray Dim gdContent As GradientDrawable gdContent.Initialize("RIGHT_LEFT", gd) Activity.Color = gd(0) PanelWithSidebar.Initialize(Activity, 200dip, 1, 1, 200, 200) PanelWithSidebar.ContentPanel.Background = gdContent PanelWithSidebar.Sidebar.Background = PanelWithSidebar.LoadDrawable("jog_tab_bar_left_end_normal") PanelWithSidebar.SetOnChangeListeners(Me, "Sidebar_onFullyOpen", "Sidebar_onFullyClosed", "Sidebar_onMove") PanelWithSidebar.ContentPanel.LoadLayout("menu") Dim r As Reflector r.Target = PanelWithSidebar.Sidebar r.RunMethod4("setPadding", Array As Object(0, 0, 0, 0), Array As String("java.lang.int", "java.lang.int", "java.lang.int", "java.lang.int")) lv1.Initialize("lvMenu") lv1.AddTwoLinesAndBitmap("صفحه اسلی","",LoadBitmap(File.DirAssets,"home.png")) lv1.AddTwoLinesAndBitmap("فهرست","",LoadBitmap(File.DirAssets,"to.png")) lv1.AddTwoLinesAndBitmap("علاقه مندی ها","",LoadBitmap(File.DirAssets,"f.png")) lv1.AddTwoLinesAndBitmap("ارتباط با ما","",LoadBitmap(File.DirAssets,"co.png")) lv1.AddTwoLinesAndBitmap("درباره ی ما","",LoadBitmap(File.DirAssets,"abo.png")) lv1.AddTwoLinesAndBitmap("خروج","",LoadBitmap(File.DirAssets,"ex.png")) lv1.Color = Colors.RGB(189, 139, 203) lv1.ScrollingBackgroundColor = Colors.Transparent '---------------------- Dim lbltxtsidebar As Label lbltxtsidebar = lv1.TwoLinesAndBitmap.Label lbltxtsidebar.left = lbltxtsidebar.Left - 90dip lbltxtsidebar.Top=lbltxtsidebar.Top+15dip lbltxtsidebar.TextColor=Colors.RGB(13, 10, 62) lbltxtsidebar.TextSize = 15 myview(lbltxtsidebar,20,"yekan") PanelWithSidebar.Sidebar.AddView(lv1, 2dip, 0, PanelWithSidebar.Sidebar.Width , PanelWithSidebar.Sidebar.Height - 40dip) Dim bg1(2) As Int bg1(0) = Colors.RGB(21, 42, 96) bg1(1) = Colors.RGB(27, 54, 124) PanelWithSidebar.Sidebar.Color=Colors.RGB(189, 139, 203) '------------------------------------------------------------' PanelWithSidebar.EnableSwipeGesture(True, 40dip, 1) lv.AddTwoLinesAndBitmap2("فهرست","فهرست",LoadBitmap(File.DirAssets,"to.png"),1) lv.AddTwoLinesAndBitmap2("جستجو","جستجو",LoadBitmap(File.DirAssets,"ser.png"),2) lv.AddTwoLinesAndBitmap2("علاقه مندی ","علاقه مندی",LoadBitmap(File.DirAssets,"f.png"),3) lv.AddTwoLinesAndBitmap2("تنظیمات","تنظیمات",LoadBitmap(File.DirAssets,"set.png"),4) lv.AddTwoLinesAndBitmap2("درباره ما","درباره ما",LoadBitmap(File.DirAssets,"abo.png"),5) lv.TwoLinesAndBitmap.Label.Gravity = Gravity.CENTER lv.TwoLinesAndBitmap.Label.TextColor = Colors.black 'data base>>----------------- If File.Exists(File.DirInternal,"e1.db")=False Then File.Copy(File.DirAssets,"e1.db",File.DirInternal,"e1.db") End If If sql1.IsInitialized=False Then sql1.Initialize(File.DirInternal,"e1.db",False) cur = sql1.ExecQuery("SELECT * FROM tbl1") End If ch.Text="1" timer1.Initialize("timer1",3000) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub myview(which As Label,fontsize As Int,fontname As String) which.Typeface=Typeface.LoadFromAssets(fontname&".ttf") which.TextColor=Colors.White which.TextSize=fontsize which.Gravity= Gravity.RIGHT which.TextColor=Colors.White End Sub Sub lvMenu_ItemClick (Position As Int, Value As Object) Log(Value) Select Case Value Case "صفحه اصلی" StartActivity("menu") Case "فهرست" Case "علاقه مندی ها" Case "ارتباط با ما" Case "درباره ی ما" Case "خروج" Exit End Select PanelWithSidebar.CloseSidebar End Sub Sub Activity_KeyPress (KeyCode As Int) As Boolean If KeyCode = KeyCodes.KEYCODE_BACK Then If ch.Text="3" Then Activity.removeallviews Activity.LoadLayout("menu") ch.Text="1" Return True End If If ch.Text="2" Then Activity.removeallviews Activity.LoadLayout("menu") ch.Text="1" Return True End If If ch.Text="22" Then Activity.removeallviews Activity.LoadLayout("menu") ch.Text="1" Return True End If If ch.Text="222" Then Activity.removeallviews Activity.LoadLayout("menu") ch.Text="1" Return True End If If ch.Text="14" Then Activity.removeallviews Activity.LoadLayout("menu") ch.Text="1" Return True End If If ch.Text="1" Then If it = False Then timer1.Enabled = True ToastMessageShow("برای خروج دوباره کلید بازگشت رو بزن",False) it = True Return True Else Return False End If End If End If End Sub Sub timer1_tick If sec <= 3 Then sec = sec+1 Else it = False timer1.Enabled = False End If End Subلینک ارسال
