مشکل در اجرای تب هاست متریال
reza16
با سلام دوستان برای اجرای tabhost ایراد میگیره لطفا راهنمایی کنید
B4A version: 5.50
Parsing code.    (0.00s)
Compiling code.    (0.06s)
Compiling layouts code.    (0.00s)
Generating R file.    Error
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:20: error: Error: No resource found that matches the given name (at 'paddingTop' with value '@dimen/snackbar_padding_vertical').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:20: error: Error: No resource found that matches the given name (at 'paddingBottom' with value '@dimen/snackbar_padding_vertical').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:20: error: Error: No resource found that matches the given name (at 'paddingLeft' with value '@dimen/snackbar_padding_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:20: error: Error: No resource found that matches the given name (at 'paddingRight' with value '@dimen/snackbar_padding_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:20: error: Error: No resource found that matches the given name (at 'maxLines' with value '@integer/snackbar_text_max_lines').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'layout_marginLeft' with value '@dimen/snackbar_extra_spacing_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'layout_marginStart' with value '@dimen/snackbar_extra_spacing_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'paddingTop' with value '@dimen/snackbar_padding_vertical').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'paddingBottom' with value '@dimen/snackbar_padding_vertical').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'paddingLeft' with value '@dimen/snackbar_padding_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'paddingRight' with value '@dimen/snackbar_padding_horizontal').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\layout\layout_snackbar_include.xml:34: error: Error: No resource found that matches the given name (at 'textAppearance' with value '@style/TextAppearance.Design.Snackbar.Action').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\drawable\snackbar_background.xml:20: error: Error: No resource found that matches the given name (at 'radius' with value '@dimen/snackbar_background_corner_radius').
c:\program files (x86)\android\android-sdk\extras\android\support\design\res\drawable\snackbar_background.xml:21: error: Error: No resource found that matches the given name (at 'color' with value '@color/snackbar_background_color').
برای استفاده از این کتابخونه باید از Support Library ورژن 23 به بالا استفاده کنی
شما لینک دانلودش رو دارید بذارید برام
باز هم نشد
دوست عزیزآدرس دهی فایلهات اشتباست نمیتونه فایل های مورد نیازو بخونه
