سلام دوستان من در مورد Limit دادن به کتاب های چند فصلی مشکل دارم . اگه راهنمایی فرمایید ممنون میشم.
کدها را گذاشتم بفرمایید چجوری باید تغییر داد؟
#Region Activity Attributes
#FullScreen: false
#IncludeTitle: false
#End Region
Dim meghdar2 As String
Dim cur As Cursor
Private sv As ScrollView
Private zironvan As Label
Private label1 As Label
Dim font As Typeface
Activity.LoadLayout("matn")
cur = menu.sql1.ExecQuery("SELECT * FROM tbl_sms WHERE grooh = '" & menu.meghdar & "'")
Dim size As Int
size = 0
For i = 0 To cur.RowCount -1
cur.Position = i
Dim p1 As Panel
p1.Initialize("")
sv.Panel.AddView(p1,3%x,size,95%x,68dip)
p1.LoadLayout("formonvan")
size = size + 70dip
label1.TextSize = 17
label1.Text = cur.GetString("onvan")
zironvan.Text = cur.GetString("grooh")
label1.TextColor = Colors.Black
label1.Gravity = Gravity.CENTER
font = Typeface.LoadFromAssets("arbaeen.ttf")
label1.Typeface = font
zironvan.Typeface = font
sv.Panel.Height = (cur.RowCount * 70dip) + 2dip
sv.Panel.Color = Colors.Transparent
Sub Activity_Resume
Sub label1_Click
ToastMessageShow("در حال بارگذاری ...",False)
label1 = Sender
label1.TextColor = Colors.White
meghdar2 = label1.Text
StartActivity(matn)
اگه نیاز به توضیح بیشتر دادره بفرمایید ، توضیح دهم.
qasem 249
#Region Activity Attributes #FullScreen: false #IncludeTitle: false #End Region Sub Process_Globals Dim meghdar2 As String End Sub Sub Globals Dim cur As Cursor Private sv As ScrollView Private zironvan As Label Private label1 As Label Dim font As Typeface End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("matn") cur = menu.sql1.ExecQuery("SELECT * FROM tbl_sms WHERE grooh = '" & menu.meghdar & "'") Dim size As Int size = 0 For i = 0 To cur.RowCount -1 cur.Position = i Dim p1 As Panel p1.Initialize("") sv.Panel.AddView(p1,3%x,size,95%x,68dip) p1.LoadLayout("formonvan") size = size + 70dip label1.TextSize = 17 label1.Text = cur.GetString("onvan") zironvan.Text = cur.GetString("grooh") label1.TextColor = Colors.Black label1.Gravity = Gravity.CENTER font = Typeface.LoadFromAssets("arbaeen.ttf") label1.Typeface = font zironvan.Typeface = font Next sv.Panel.Height = (cur.RowCount * 70dip) + 2dip sv.Panel.Color = Colors.Transparent End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub label1_Click ToastMessageShow("در حال بارگذاری ...",False) label1 = Sender label1.TextColor = Colors.White meghdar2 = label1.Text StartActivity(matn) End Subاگه نیاز به توضیح بیشتر دادره بفرمایید ، توضیح دهم.
19 پاسخ به این سوال تاکنون داده شده است
