کدهای زیر رو که گذاشتم ببینید و لطفا هر کس میتونه برام تبدیل انجام بده
*** کدها مربوط به فراخوانی دو جدول یک دیتابیس میباشد.
Activity (main)e
Private Listview1 As ListView
Listview1.AddTwoLinesAndBitmap2("second title","first title",LoadBitmap(File.DirAssets,"x.png"),1)
Listview1.AddTwoLinesAndBitmap2("second title","first title",LoadBitmap(File.DirAssets,"xx.png"),2)
Sub Listview1_ItemClick (Position As Int, Value As Object)
If Value = 1 Then
StartActivity(tabel1)
Else If Value = 2 Then
StartActivity(tabel2)
Activity(tabel1)e
Dim sql1 As SQL
Dim cur As Cursor
Dim meghdar As String
Dim fara As Farakhani
Activity.LoadLayout("tabel1")
fara.SingleLineTitr("data.db",sql1,cur,"SELECT * FROM tabel1",Listview1,"titr","id")
meghdar = Value
StartActivity(matn_tabel1)
Activity(matn_tabel1)e
Private Label1 As Label
Activity.LoadLayout("matn")
fara.FarakhaniMatn("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel1 WHERE id=",tabel1.meghdar,Label1,"matn")
Activity (tabel2)e
Dim meghdar2 As String
Activity.LoadLayout("tabel2")
fara.SingleLineTitr("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel2",Listview1,"titr","id")
meghdar2 = Value
StartActivity(matn_tabel2)
Activity(matn_tabel2)e
fara.FarakhaniMatn("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel2 WHERE id=",tabel2.meghdar2,Label1,"matn")
love-learning 3
سلام عزیزان
Activity (main)e
Sub Globals Private Listview1 As ListView End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("Layout1") Listview1.AddTwoLinesAndBitmap2("second title","first title",LoadBitmap(File.DirAssets,"x.png"),1) Listview1.AddTwoLinesAndBitmap2("second title","first title",LoadBitmap(File.DirAssets,"xx.png"),2) End Sub Sub Listview1_ItemClick (Position As Int, Value As Object) If Value = 1 Then StartActivity(tabel1) Else If Value = 2 Then StartActivity(tabel2) End If End SubActivity(tabel1)e
Sub Process_Globals Dim sql1 As SQL Dim cur As Cursor Dim meghdar As String End Sub Sub Globals Private Listview1 As ListView Dim fara As Farakhani End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("tabel1") fara.SingleLineTitr("data.db",sql1,cur,"SELECT * FROM tabel1",Listview1,"titr","id") End Sub Sub Listview1_ItemClick (Position As Int, Value As Object) meghdar = Value StartActivity(matn_tabel1) End SubActivity(matn_tabel1)e
Sub Globals Dim fara As Farakhani Private Label1 As Label End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("matn") fara.FarakhaniMatn("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel1 WHERE id=",tabel1.meghdar,Label1,"matn") End SubActivity (tabel2)e
Sub Process_Globals Dim meghdar2 As String End Sub Sub Globals Dim fara As Farakhani Private Listview1 As ListView End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("tabel2") fara.SingleLineTitr("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel2",Listview1,"titr","id") End Sub Sub Listview1_ItemClick (Position As Int, Value As Object) meghdar2 = Value StartActivity(matn_tabel2) End SubActivity(matn_tabel2)e
Sub Globals Dim fara As Farakhani Private Label1 As Label End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("matn") fara.FarakhaniMatn("data.db",tabel1.sql1,tabel1.cur,"SELECT * FROM tabel2 WHERE id=",tabel2.meghdar2,Label1,"matn") End Subلینک ارسال
