اسکرول متن در دیتابیس
reza644
واسه اسکرول متن از چه کدی استفاده کنم؟
از کتابخانه فراخوانی 2 استفاده کردم
ts.LongText(lbl,lbl.Text,l.Text,ScrollView1,"1.5")
عدد 1.5 رو بدون کوتیشن بزارید
این ارور رو میده
کد هام
#Region  Activity Attributes
	#FullScreen: False
	#IncludeTitle: False
#End Region
Dim lbl As Label
Dim fara As Farakhani
Dim share As Intent
	Private Button1 As Button
	Private Button2 As Button
	Dim ts As TextSetting
	Dim l As Label
	Dim cafe As Intent
	Activity.LoadLayout("scroll")
lbl.Initialize("")
l.Initialize("")
ts.Initialize
lbl.TextColor=Colors.Black
	If(File.Exists(File.DirRootExternal,"textsize.txt")) Then
		lbl.Textsize=File.GetText(File.DirRootExternal,"textsize"&".txt")
		l.Text=File.GetText(File.DirRootExternal,"textsize"&".txt")
lbl.Textsize=13
Button1.TextSize=22
Button2.TextSize=22
	If(File.Exists(File.DirRootExternal,"textfont.txt")) Then
	Dim str2 As String
str2 = File.readString(File.DirRootExternal,"textfont"&".txt")
If str2 = "IRYekan.ttf" Then
lbl.Typeface=Typeface.LoadFromAssets("IRYekan.ttf")
Button1.Typeface=Typeface.LoadFromAssets("IRYekan.ttf")
Button2.Typeface=Typeface.LoadFromAssets("IRYekan.ttf")
Button1.TextSize=15
Button2.TextSize=15
else if str2 = "danstevis.otf" Then
	Button1.Typeface=Typeface.LoadFromAssets("danstevis.otf")
lbl.Typeface=Typeface.LoadFromAssets("danstevis.otf")
Button2.Typeface=Typeface.LoadFromAssets("danstevis.otf")
Button1.TextSize=22
Button2.TextSize=22
else if str2 = "B Traffic_0.ttf" Then
	Button1.Typeface=Typeface.LoadFromAssets("B Traffic_0.ttf")
lbl.Typeface=Typeface.LoadFromAssets("B Traffic_0.ttf")
Button2.Typeface=Typeface.LoadFromAssets("B Traffic_0.ttf")
Button1.TextSize=22
Button2.TextSize=22
else if str2 = "IranNastaliq.ttf" Then
	Button1.Typeface=Typeface.LoadFromAssets("IranNastaliq.ttf")
	Button2.Typeface=Typeface.LoadFromAssets("IranNastaliq.ttf")
Button1.TextSize=22
Button2.TextSize=22
lbl.Typeface=Typeface.LoadFromAssets("IranNastaliq.ttf")
else if str2 = "phalls_khodkar.ttf" Then
	Button1.Typeface=Typeface.LoadFromAssets("phalls_khodkar.ttf")
	Button2.Typeface=Typeface.LoadFromAssets("phalls_khodkar.ttf")
Button1.TextSize=22
Button2.TextSize=22
lbl.Typeface=Typeface.LoadFromAssets("phalls_khodkar.ttf")
Button1.TextSize=15
Button2.TextSize=15
	If(File.Exists(File.DirRootExternal,"textcolor.txt")) Then
	Dim str As String
str = File.readString(File.DirRootExternal,"textcolor"&".txt")
If str = "Colors.Black" Then
lbl.textColor = Colors.Black
else if str = "Colors.Red" Then
lbl.textColor = Colors.Red
else if str = "Colors.Blue" Then
lbl.textColor = Colors.Blue
fara.FarakhaniMatn("reza.db",Main.sql1,Main.cur,"SELECT * FROM khat where id=",khaterat.meghdar3,lbl,"matn")
ScrollView1.Panel.AddView(lbl,0,0,100%x,100%y)
	lbl.Gravity=Gravity.RIGHT
share.Initialize(share.ACTION_SEND,"")
share.SetType("text/plain")
share.PutExtra("android.intent.extra.TEXT", lbl.Text)
    Dim verticalPosition As String = "bottom" '"top" or "bottom"
    Dim horizontalPosition As String = "center" '"left", "right" or "center"
    Dim r As Reflector
    Dim args(3) As Object = Array As Object(r.GetActivity, verticalPosition, horizontalPosition)
    Dim types(3) As String = Array As String("android.app.Activity", "java.lang.String", "java.lang.String")
    r.RunStaticMethod("ir.adad.AdadB4APlugin", "createAdView", args, types)
Sub Activity_Resume
Sub ScrollView1_ScrollChanged(Position As Int)
 Sub Button1_click
 share.WrapAsIntentChooser("اشتراک بگذاريد")
StartActivity(share)
Sub Button2_Click
	cafe.Initialize(cafe.ACTION_EDIT,"bazaar://details?id=com.defa.app.book")
	StartActivity(cafe)
برنامه رو در حالت Debug Legecy اجرا کنید ببینید دقیقا از کدوم خط خطا گرفته ؟
