مهدی ایزدی 9,203 ارسال شده در 8 اردیبهشت، 2016 اشتراک گذاری ارسال شده در 8 اردیبهشت، 2016 از طریق این کتابخانه می توانید طیفی از رنگ ها را از طریق SeekBar مشاهده و انتخاب کنید این کتابخانه قابلیت های فراوانی دارد از قبیل میزان Alpha رنگ به صورت SeekBar با قابلیت غیر فعال کردن نمایش آن و بسیاری قابلیت های دیگر که در زیر مشاهده میکنید : Events ColorChanged (colorBarValue As Int, alphaValue As Int, color As Int) Fields: ba As BA Methods: AddToParent (Parent As ViewGroup, left As Int, top As Int, width As Int, height As Int) BringToFront DesignerCreateView (base As PanelWrapper, lw As LabelWrapper, props As Map) Initialize (EventName As String) Invalidate Invalidate2 (arg0 As Rect) Invalidate3 (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int) IsInitialized As Boolean RemoveView RequestFocus As Boolean SendToBack SetBackgroundImage (arg0 As Bitmap) SetColorAnimated (arg0 As Int, arg1 As Int, arg2 As Int) SetLayout (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int) SetLayoutAnimated (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int, arg4 As Int) SetVisibleAnimated (arg0 As Int, arg1 As Boolean) dp2px (dpValue As Float) As Int isShowAlphaBar As Boolean Properties: AlphaBarValue As Int [write only] AlphaValue As Int [read only] Background As Drawable BarHeight As Int BarHeightPx As Int [write only] BarMargin As Int set margin between bars BarMarginPx As Int [write only] set margin between bars Color As Int ColorBarValue As Int [write only] Set the value of color bar, if out of bounds , it will be 0 or maxValue; ColorPosition As Float [read only] ColorWithAlpha As Int [read only] Colors() As Int [read only] Enabled As Boolean Height As Int Left As Int MaxValue As Int OnColorChangeListener As OnColorChangeListener [write only] ShowAlphaBar As Boolean [write only] Tag As Object ThumbHeight As Int set thumb's height by dpi ThumbHeightPx As Int [write only] set thumb's height by pixels Top As Int Visible As Boolean Width As Int دموی متریال این کتابخانه :برای مشاهده کلیک کنید لینک خرید از فروشگاه 2 نقل قول لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
به گفتگو بپیوندید
