از طریق این کتابخانه می توانید طیفی از رنگ ها را از طریق SeekBar مشاهده و انتخاب کنید
این کتابخانه قابلیت های فراوانی دارد از قبیل میزان Alpha رنگ به صورت SeekBar با قابلیت غیر فعال کردن نمایش آن و بسیاری قابلیت های دیگر
که در زیر مشاهده میکنید :
Events
 ColorChanged (colorBarValue As Int, alphaValue As Int, color As Int)
Fields:
ba As BA
Methods:
AddToParent (Parent As ViewGroup, left As Int, top As Int, width As Int, height As Int)
BringToFront
DesignerCreateView (base As PanelWrapper, lw As LabelWrapper, props As Map)
Initialize (EventName As String)
Invalidate
Invalidate2 (arg0 As Rect)
Invalidate3 (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int)
IsInitialized As Boolean
RemoveView
RequestFocus As Boolean
SendToBack
SetBackgroundImage (arg0 As Bitmap)
SetColorAnimated (arg0 As Int, arg1 As Int, arg2 As Int)
SetLayout (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int)
SetLayoutAnimated (arg0 As Int, arg1 As Int, arg2 As Int, arg3 As Int, arg4 As Int)
SetVisibleAnimated (arg0 As Int, arg1 As Boolean)
dp2px (dpValue As Float) As Int
isShowAlphaBar As Boolean
Properties:
AlphaBarValue As Int [write only]
AlphaValue As Int [read only]
Background As Drawable
BarHeight As Int
BarHeightPx As Int [write only]
BarMargin As Int
set margin between bars
BarMarginPx As Int [write only]
Color As Int
ColorBarValue As Int [write only]
Set the value of color bar, if out of bounds , it will be 0 or maxValue;
ColorPosition As Float [read only]
ColorWithAlpha As Int [read only]
Colors() As Int [read only]
Enabled As Boolean
Height As Int
Left As Int
MaxValue As Int
OnColorChangeListener As OnColorChangeListener [write only]
ShowAlphaBar As Boolean [write only]
Tag As Object
ThumbHeight As Int
set thumb's height by dpi
ThumbHeightPx As Int [write only]
set thumb's height by pixels
Top As Int
Visible As Boolean
Width As Int
دموی متریال این کتابخانه :
برای مشاهده کلیک کنید
لینک خرید از فروشگاه
ارسال پاسخ به این موضوع ...
