بنده با نمایش عکس از دیتابیس مشکل دارم و کد زیر رو خطا میگیره .
bytes=cur1.GetBlob("pictures")
اینم تمام کد :
Dim sq As SQL
Dim sr As String
Dim cu As Cursor
Private ListView1 As ListView
Private ImageView2 As ImageView
Activity.LoadLayout("ff")
File.Copy(File.DirAssets,"qq.db",File.DirInternal,"qq.db")
sq.Initialize(File.DirInternal,"qq.db",False)
cu = sq.ExecQuery("SELECT * FROM re")
For i=0 To cu.RowCount-1
cu.Position = i
ListView1.AddSingleLine(cu.GetString("esm"))
Sub Activity_Resume
ImageView2.Bitmap = Namayesh(" نام 1")
Sub Namayesh(esm As String) As Bitmap
Dim cur1 As Cursor
cur1=sq.ExecQuery("SELECT * FROM re WHERE Esm='"& esm & "'")
cur1.Position=0
Dim bytes() As Byte
Dim input As InputStream
input.InitializeFromBytesArray(bytes,0,bytes.Length)
Dim b As Bitmap
b.Initialize2(input)
input.Close
Return(b)
Amir - B 185
bytes=cur1.GetBlob("pictures")اینم تمام کد :
Sub Process_Globals Dim sq As SQL Dim sr As String End Sub Sub Globals Dim cu As Cursor Private ListView1 As ListView Private ImageView2 As ImageView End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("ff") File.Copy(File.DirAssets,"qq.db",File.DirInternal,"qq.db") sq.Initialize(File.DirInternal,"qq.db",False) cu = sq.ExecQuery("SELECT * FROM re") For i=0 To cu.RowCount-1 cu.Position = i ListView1.AddSingleLine(cu.GetString("esm")) Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub ListView1_ItemClick (Position As Int, Value As Object) ImageView2.Bitmap = Namayesh(" نام 1") End Sub Sub Namayesh(esm As String) As Bitmap Dim cur1 As Cursor cur1=sq.ExecQuery("SELECT * FROM re WHERE Esm='"& esm & "'") cur1.Position=0 Dim bytes() As Byte bytes=cur1.GetBlob("pictures") Dim input As InputStream input.InitializeFromBytesArray(bytes,0,bytes.Length) Dim b As Bitmap b.Initialize2(input) input.Close Return(b) End Subلینک ارسال
