scrollveiw ایجاد کردم و نمایش هم داده میشه. اما ثابت هست و اسکرول نمیشه. یعنی صفحه بالا و پایین نمیره.
ممنون میشم مشکل رو بگین. اینم سورس:
Dim tmr As Timer
Dim s As SQL
tmr.Initialize("Timer",2500)
Activity.LoadLayout("frm1")
tmr.Enabled=True
If File.Exists(File.DirInternal,"ketabdb.db")=False Then
File.Copy(File.DirAssets,"ketabdb.db",File.DirInternal,"ketabdb.db")
If s.IsInitialized=False Then
s.Initialize(File.DirInternal,"ketabdb.db",False)
Dim cur As Cursor
cur=s.ExecQuery("select * from tbl1")
Dim h As Int
h=2%y
For I=0 To cur.RowCount-1
cur.Position=I
Dim btn As Button
btn.Initialize("btn")
btn.Text=cur.GetString("onvan")
btn.Tag=I+1
Dim b As BitmapDrawable
b.Initialize(LoadBitmap(File.DirAssets,"icon2.png"))
btn.Background=b
ScrollView1.Panel.AddView(btn,0,h,65%x,25%y)
h=h+27%y
سیدمحمد 248
سلام دوستان.
Sub Process_Globals . Dim tmr As Timer Dim s As SQL End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. tmr.Initialize("Timer",2500) Private ImageView1 As ImageView Private ScrollView1 As ScrollView End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("frm1") tmr.Enabled=True If File.Exists(File.DirInternal,"ketabdb.db")=False Then File.Copy(File.DirAssets,"ketabdb.db",File.DirInternal,"ketabdb.db") End If If s.IsInitialized=False Then s.Initialize(File.DirInternal,"ketabdb.db",False) End If Dim cur As Cursor cur=s.ExecQuery("select * from tbl1") Dim h As Int h=2%y For I=0 To cur.RowCount-1 cur.Position=I Dim btn As Button btn.Initialize("btn") btn.Text=cur.GetString("onvan") btn.Tag=I+1 Dim b As BitmapDrawable b.Initialize(LoadBitmap(File.DirAssets,"icon2.png")) btn.Background=b ScrollView1.Panel.AddView(btn,0,h,65%x,25%y) h=h+27%y Next End Subلینک ارسال
