ارور هنگام استفاده از پوشه
hemmaty76
خسته نباشین
من برا اولین بار اومدم از پوشه استفاده کنم
کتابخونه های گوگلو اضافه کردم
ادرس پوشه res هم دادم اما موقع اجرا به محتوای این پوشه ها ارور میده اینم ارور طولانیش
B4A version: 5.80
Parsing code.    (0.04s)
Compiling code.    (0.21s)
Compiling layouts code.    (0.01s)
Generating R file.    (3.49s)
Compiling generated Java code.    (1.82s)
Convert byte code - optimized dex.    (5.50s)
Packaging files.    Error
    (skipping index file 'res\drawable-hdpi\Thumbs.db')
    (skipping index file 'res\drawable-ldpi\Thumbs.db')
    (skipping index file 'res\drawable-mdpi\Thumbs.db')
    (skipping index file 'res\drawable-xhdpi\Thumbs.db')
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_dark.9.png malformed.
       Ticks in transparent frame must be black.
       Found at pixel #5 along bottom edge.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_focus_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_focus_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_focus_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_focus_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_disabled_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_focus_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_focus_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_focus_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_focus_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_normal_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_normal_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_normal_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_normal_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_pressed_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_pressed_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_pressed_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_icon_pressed_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_focus_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_focus_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_focus_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_focus_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_disabled_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_focus_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_focus_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_focus_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_focus_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_normal_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_normal_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_normal_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_normal_light.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_pressed_dark.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_pressed_dark.9.png
ERROR: 9-patch image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_pressed_light.9.png malformed.
ERROR: Failure processing PNG image c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable-mdpi\common_signin_btn_text_pressed_light.9.png
res\layout\system_window_decorators.xml:2: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/border').
res\layout\system_window_decorators.xml:36: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/hide').
res\layout\system_window_decorators.xml:43: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/maximize').
res\layout\system_window_decorators.xml:50: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/close').
res\layout\system_window_decorators.xml:65: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/corner').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_dark.xml:3: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_pressed_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_dark.xml:6: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_disabled_focus_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_dark.xml:10: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_focus_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_dark.xml:13: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_disabled_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_dark.xml:16: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_normal_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_light.xml:3: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_pressed_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_light.xml:6: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_disabled_focus_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_light.xml:10: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_focus_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_light.xml:13: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_disabled_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_icon_light.xml:16: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_icon_normal_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_dark.xml:3: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_pressed_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_dark.xml:6: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_disabled_focus_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_dark.xml:10: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_focus_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_dark.xml:13: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_disabled_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_dark.xml:16: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_normal_dark').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_light.xml:3: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_pressed_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_light.xml:6: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_disabled_focus_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_light.xml:10: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_focus_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_light.xml:13: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_disabled_light').
c:\users\iran\desktop\pushe\google play service-low size\google play service-low size\google-play-services-base-7.5.0\res\drawable\common_signin_btn_text_light.xml:16: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/common_signin_btn_text_normal_light').
ایراد کار چیه؟
به نظر من هم ایراد از کدهای مانفیست هست. از سایت پوشه دانلود کن و قرار بده.
sdk 14 هستش
'See this link for for more information: http://www.basic4ppc.com/forum/showthread.php?p=78136
AddManifestText(
<uses-sdk android:minSdkVersion="16" android:targetSdkVersion="19"/>
    android:normalScreens="true"
    android:smallScreens="true"
    android:anyDensity="true"/>)
AddApplicationText(<service android:name="com.rootsoft.rsstandout.RSStandOutWindow"  />)
SetApplicationAttribute(android:theme, "@android:style/Theme.Holo.Light")
 AddPermission(android.permission.ACCESS_NETWORK_STATE)
AddApplicationText(<receiver android:name="anywheresoftware.b4a.objects.AdminManager$AdminReceiver"
android:permission="android.permission.BIND_DEVICE_ADMIN">
<meta-data android:name="android.app.device_admin"
android:resource="@xml/device_admin" />
<intent-filter>
<action android:name="android.app.action.DEVICE_ADMIN_ENABLED" />
</intent-filter>
</receiver>)
AddManifestText(
	<permission
		android:name="ir.valetvoise.permission.C2D_MESSAGE"
		android:protectionLevel="signature" />
	<uses-permission android:name="ir.valetvoise.permission.C2D_MESSAGE" />
	<!-- Optional permissions -->
	<uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
	<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
	<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
	<uses-permission android:name="android.permission.READ_PHONE_STATE"/>
AddApplicationText(
	<receiver android:name="co.ronash.pushe.receiver.UpdateReceiver" >
		<intent-filter>
			<action android:name="android.intent.action.PACKAGE_REPLACED" />
			<data
				android:path="ir.valetvoise"
				android:scheme="package" />
		</intent-filter>
	</receiver>
	<receiver
		android:name="com.google.android.gms.gcm.GcmReceiver"
		android:exported="true"
		android:permission="com.google.android.c2dm.permission.SEND" >
		<intent-filter>
			<action android:name="com.google.android.c2dm.intent.RECEIVE" />
			<action android:name="com.google.android.c2dm.intent.REGISTRATION" />
			<category android:name="ir.valetvoise" />
		</intent-filter>
	</receiver>
	<service
		android:name="co.ronash.pushe.service.GcmService"
		android:exported="false" >
		<intent-filter>
		</intent-filter>
	</service>
	<receiver
		android:name="co.ronash.pushe.receiver.FallbackGcmNetworkManagerReceiver"
		android:exported="true" >
		<intent-filter>
			<action android:name="co.ronash.pushe.CHECK_TASKS" />
		</intent-filter>
	</receiver>
	<service
		android:name="co.ronash.pushe.service.FallbackGcmTaskRunner"
		<intent-filter>
			<action android:name="co.ronash.pushe.ACTION_TASK_READY" />
		</intent-filter>
	</service>
	<service
		android:name="co.ronash.pushe.service.GcmTaskRunner"
		android:permission="com.google.android.gms.permission.BIND_NETWORK_TASK_SERVICE" >
		<intent-filter>
			<action android:name="com.google.android.gms.gcm.ACTION_TASK_READY" />
		</intent-filter>
	</service>
	<service
		android:name="co.ronash.pushe.service.IntentTaskRunner"
		android:exported="false" />
	<service
		android:name="co.ronash.pushe.service.InstanceIDService"
		<intent-filter>
			<action android:name="com.google.android.gms.iid.InstanceID" />
		</intent-filter>
	</service>
	<activity
		android:name="co.ronash.pushe.activities.PopupDialogActivity"
		android:theme="@style/PusheTransparent">
	</activity>
	<meta-data android:name="com.google.android.gms.version" android:value="@integer/google_play_services_version"/>
	<meta-data android:name="co.ronash.pushe.token" android:value="6b-1e23-45_414020120187"/>
یه قسمت ک نوشته بود اس دی کا من 14 هست و 16 کردم تو اموزشش گفته بود.فکر کنم sdk اپدیت نیس :sorry:  حجمم ندارم :ireful:
منهم اولین بار همین مشکل رو داشتم. زنگ زدم به پشتیبانی سایت و مشکل حل شد!!!! به حجم دو تا فایل گوگل که داخل پوشه برنامه کپی کردی دقت کن، برای من حجمشون یک کیلوبایت بود، اونا رو دوباره کپی کردم و به همین راحتی به همین خوشمزگی!!!!
دوستان من sdk tools رو اپدیت کردم بازم همون ارور رو میده
چیز دیگم باید اپدیت کنم؟ میشه فایلشو بزارین اعصابمو ریخته بهم :sorry:
با api 23 کامپایل کن شاید درست شد، اینم لینک دانلودش
http://answercenter.ir/topic/1503-مجموعه-کامل-sdk-های-اندروید/
حیف sample اش نیس من خودمم با زورو زحمت لینک سمپلو پیدا کردم وگرنه براتون میزاشتم، نصف ب نصف ارورام با آپدیت کامل Sdk از بین رفت
دوسته گلم pedro رو لینک آپدیت و دادن من همرو آپدیت کردم ی سیستم ایمیج مونده ک اونم ربطی ارور نداره
کد های مانیفیستم ک گذاشتم
این ارور ها یعنی چی پس
Sdk ک آپدیته
مانیفیست رو هم ک دقیقا از خوده سایته پوشه دانلود کردم ایراد از کجاس؟
