من نمیدونم چرا برنامه رو باز میکنم فورس کلوز میشه و مشکل یعنی از کجاس
رو حالت دیباگ هم فورس کلوز میشه
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: true
#End Region
Private Panel1 As Panel
Private Panel2 As Panel
Dim ph As PackageManager
Dim p As List
Dim b As BitmapDrawable
Dim sql2 As SQL
Dim bb As BitmapDrawable
Dim appname As String
Dim packagename As String
Dim ins As String
Private Button1 As Button
Private Button2 As Button
Private EditText1 As EditText
Private P1 As Panel
Private P2 As Panel
Dim cur As Cursor
Dim ListView1 As AriaListView
Dim ar As AriaAdapterWithImage
Dim l1 As List
Dim l2 As List
Dim l3 As List
Dim ss,s As String
Dim php As PackageManager
Dim bitm As BitmapDrawable
Dim phphp As PackageManager
Dim curr As Cursor
Dim sqll As SQL
Activity.LoadLayout("amir2")
l1.Initialize
l2.Initialize
l3.Initialize
ListView1.Initialize("list")
Panel1.AddView(ListView1,0,21%x,100%x,100%y)
sql2.Initialize(File.DirInternal,"pp.db",False)
p = ph.GetInstalledPackages
For i = 0 To p.Size -1
s = p.Get(i)
ss = php.GetApplicationLabel(s)
l1.Add(ss)
bitm = phphp.GetApplicationIcon(p.Get(i))
l3.Add(bitm.Bitmap)
Log("start add")
ar.Initialize("layout_image_right",l1,l2,l3).ToListView(ListView1)
Log("finish add")
sqll.Initialize(File.DirInternal,"pp.db",False)
curr = sqll.ExecQuery("SELECT * FROM appp")
Sub Activity_Resume
Sub list_select (ParentEventName As String,position As Int)
Dim value As String
value = ListView1.GetLabelTextbyID("text1",position)
Msgbox(value,"")
Dim amir As String = value
For ia = 0 To curr.RowCount -1
curr.Position = ia
If amir.Contains(curr.GetString("textapp")) = True Then
Msgbox("این برنامه قبلا ثبت شده است لطفا برای تغییر دستور آن به بخش حذف رفته و پس از حذف دوباره امتحان کنید","خطا!")
Log("amir")
p.Initialize
For Iss = 0 To p.Size -1
Dim s As String
s = ph.GetApplicationLabel(p.Get(Iss))
If s = value Then
appname = value
packagename = p.Get(Iss)
Panel1.RemoveAllViews
Activity.RemoveAllViews
Log("remove")
Activity.LoadLayout("amir3")
Panel1.LoadLayout("amir3")
Log("load layout")
Sub Button2_Click
Msgbox("شما باید کلمه در اینجا وارد کنید به عنوان دستور که وقتی اون کلمه رو گفتید نرم افزار بیاد برنامه انتخاب شده رو باز کنه","توضیح"&CRLF&"توجه:فقط از یک کلمه استفاده کنید...در املاء کلمه دقت کنید تا برنامه عمل را بدرستی انجام دهد...از نوشتن کلمات بی معنی خودداری کنید...از کلمات فارسی استفاده کنید")
Sub Button1_Click
If EditText1.Text = "" Then
Msgbox("یک دستور بنویسید و ادامه دهید","")
For i = 0 To curr.RowCount -1
curr.Position = i
If EditText1.Text.Contains(curr.GetString("ins")) = True Then
Msgbox("این دستور قبلا ثبت شده است لطفا دستور دیگری انتخاب فرمایید","خطا!")
sql2.ExecNonQuery("INSERT INTO appp(id,textapp,package,ins) VALUES(null,'"& appname &"','"& packagename &"','"&EditText1.Text&"')")
ToastMessageShow("اعمال شد",True)
StartActivity(Main)
amir00700 66
#Region Activity Attributes #FullScreen: False #IncludeTitle: true #End Region Sub Process_Globals End Sub Sub Globals Private Panel1 As Panel Private Panel2 As Panel Dim ph As PackageManager Dim p As List Dim b As BitmapDrawable Dim sql2 As SQL Dim bb As BitmapDrawable Dim appname As String Dim packagename As String Dim ins As String Private Button1 As Button Private Button2 As Button Private EditText1 As EditText Private P1 As Panel Private P2 As Panel Dim cur As Cursor Dim ListView1 As AriaListView Dim ar As AriaAdapterWithImage Dim l1 As List Dim l2 As List Dim l3 As List Dim ss,s As String Dim php As PackageManager Dim bitm As BitmapDrawable Dim phphp As PackageManager Dim curr As Cursor Dim sqll As SQL End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("amir2") l1.Initialize l2.Initialize l3.Initialize ListView1.Initialize("list") Panel1.AddView(ListView1,0,21%x,100%x,100%y) sql2.Initialize(File.DirInternal,"pp.db",False) p = ph.GetInstalledPackages For i = 0 To p.Size -1 s = p.Get(i) ss = php.GetApplicationLabel(s) l1.Add(ss) bitm = phphp.GetApplicationIcon(p.Get(i)) l3.Add(bitm.Bitmap) Next Log("start add") ar.Initialize("layout_image_right",l1,l2,l3).ToListView(ListView1) Log("finish add") sqll.Initialize(File.DirInternal,"pp.db",False) curr = sqll.ExecQuery("SELECT * FROM appp") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub list_select (ParentEventName As String,position As Int) Dim value As String value = ListView1.GetLabelTextbyID("text1",position) Msgbox(value,"") Dim amir As String = value For ia = 0 To curr.RowCount -1 curr.Position = ia If amir.Contains(curr.GetString("textapp")) = True Then Msgbox("این برنامه قبلا ثبت شده است لطفا برای تغییر دستور آن به بخش حذف رفته و پس از حذف دوباره امتحان کنید","خطا!") Else Log("amir") p.Initialize p = ph.GetInstalledPackages For Iss = 0 To p.Size -1 Dim s As String s = ph.GetApplicationLabel(p.Get(Iss)) If s = value Then appname = value packagename = p.Get(Iss) Panel1.RemoveAllViews Activity.RemoveAllViews Log("remove") Activity.LoadLayout("amir3") Panel1.LoadLayout("amir3") Log("load layout") End If Next End If Next End Sub Sub Button2_Click Msgbox("شما باید کلمه در اینجا وارد کنید به عنوان دستور که وقتی اون کلمه رو گفتید نرم افزار بیاد برنامه انتخاب شده رو باز کنه","توضیح"&CRLF&"توجه:فقط از یک کلمه استفاده کنید...در املاء کلمه دقت کنید تا برنامه عمل را بدرستی انجام دهد...از نوشتن کلمات بی معنی خودداری کنید...از کلمات فارسی استفاده کنید") End Sub Sub Button1_Click If EditText1.Text = "" Then Msgbox("یک دستور بنویسید و ادامه دهید","") Else sqll.Initialize(File.DirInternal,"pp.db",False) curr = sqll.ExecQuery("SELECT * FROM appp") For i = 0 To curr.RowCount -1 curr.Position = i If EditText1.Text.Contains(curr.GetString("ins")) = True Then Msgbox("این دستور قبلا ثبت شده است لطفا دستور دیگری انتخاب فرمایید","خطا!") Else sql2.ExecNonQuery("INSERT INTO appp(id,textapp,package,ins) VALUES(null,'"& appname &"','"& packagename &"','"&EditText1.Text&"')") ToastMessageShow("اعمال شد",True) StartActivity(Main) End If Next End If End Subلینک ارسال
