ارور سورس appcompat
davood1382
سلام دوستان من بر اساس اموزش الیاس جان در رابطه با متریال جلو رفتم اما این ارورو داد
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:115: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner.Underlined'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:140: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:145: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:351: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:29: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:358: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:37: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:365: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:45: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:372: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files (x86)\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:53: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
من دقیقا نمیدونم ارور برای چی هست
اما خب پوشه ی ساپورت تون با ورژن اندرویدتون(تو sdk) باید یکی باشه
از اخرین نسخه ی sdk استفاده کنید
از ورژن 2 کتابخانه استفاده کنید
