Sub setting
Dim a1 As AHPreferenceScreen
a1.Initialize("تنظیمات","تنظیمات مربوط به نمایش")
a1.AddList("fontSize","اندازه قلم","حالت پیشفرض سایز قلم 18","18","",Array As String("20","21","22","28","36","40","52"))
a1.AddList("fontColor","رنگ قلم","رنگ پیشفرض قلم سیاه است","black","",Array As String("Red","Green","Blue","Yellow"))
a1.AddList("fontFamily","نوع قلم","","byekan.ttf","",Array As String("tahoma.ttf","bn.ttf"))
StartActivity(a1.CreateIntent)
android.content.ActivityNotFoundException: Unable to find explicit activity class {b4a.example/de.amberhome.objects.preferenceactivity}; have you declared this activity in your AndroidManifest.xml?
farnad24 45
سلام.من میخوام تو برنامم از تنظیمات خود گوشی با کتابخانه AHPreferenceScreen استفاده کنم .
تو قسمت مانیفست برنامه هم دسترسی زیر رو اضافه کردم ولی بازم میگه این دسترسی وجود نداره.
دسترسی اضافه شده:
(</"AddApplicationText(<activity android:name="anywheresoftware.b4a.objects.preferenceactivity
عکس دسترسی اضافه شده
کد های قسمت setting:
Sub setting Dim a1 As AHPreferenceScreen a1.Initialize("تنظیمات","تنظیمات مربوط به نمایش") a1.AddList("fontSize","اندازه قلم","حالت پیشفرض سایز قلم 18","18","",Array As String("20","21","22","28","36","40","52")) a1.AddList("fontColor","رنگ قلم","رنگ پیشفرض قلم سیاه است","black","",Array As String("Red","Green","Blue","Yellow")) a1.AddList("fontFamily","نوع قلم","","byekan.ttf","",Array As String("tahoma.ttf","bn.ttf")) StartActivity(a1.CreateIntent) End Subعکس کد های قسمت setting
ارور:
android.content.ActivityNotFoundException: Unable to find explicit activity class {b4a.example/de.amberhome.objects.preferenceactivity}; have you declared this activity in your AndroidManifest.xml?لینک ارسال
