سلام دوستان موقع اجرا جدول دوم از یک دیتابیس در یک اکتیویتی مجزا با این خطلا موجه می شم اگه دوستان راهنمایی کنند ممنون می شم android.database.sqlite.SQLiteException: no such table: dar (code 1): , while compiling: SELECT * FROM dar پایین هم سورسی که ایراد میگیره
Dim sql1 As SQL
Dim cur2 As Cursor
Private AutoCompleteEditText1 As AutoCompleteEditText
Private AutoCompleteEditText2 As AutoCompleteEditText
Private EditText1 As EditText
Private EditText2 As EditText
Private Label1 As Label
Private Label2 As Label
Private Label3 As Label
Private Spinner1 As Spinner
Private Spinner2 As Spinner
Private Spinner3 As Spinner
Private Label4 As Label
Private ListView1 As ListView
Activity.LoadLayout("main2")
If File.Exists(File.DirInternal,"taxi.db")=False Then
File.Copy(File.DirAssets,"taxi.db",File.DirInternal,"taxi.db")
sql1.Initialize(File.DirInternal,"taxi.db",False)
cur2=sql1.ExecQuery("select * from dar")
For i=0 To cur2.RowCount-1
cur2.Position=i
ListView1.AddSingleLine(cur2.GetInt("id") &"|"&cur2.GetString("tarikh") &"|"&cur2.GetString("mosafer") &"|"&cur2.GetString("maghsad") &"|"&cur2.GetString("keraye") &"|"&cur2.GetString("com"))
imanarman 2
Sub Process_Globals Dim sql1 As SQL End Sub Sub Globals Dim cur2 As Cursor Private AutoCompleteEditText1 As AutoCompleteEditText Private AutoCompleteEditText2 As AutoCompleteEditText Private EditText1 As EditText Private EditText2 As EditText Private Label1 As Label Private Label2 As Label Private Label3 As Label Private Spinner1 As Spinner Private Spinner2 As Spinner Private Spinner3 As Spinner Private Label4 As Label Private ListView1 As ListView End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("main2") If File.Exists(File.DirInternal,"taxi.db")=False Then File.Copy(File.DirAssets,"taxi.db",File.DirInternal,"taxi.db") End If sql1.Initialize(File.DirInternal,"taxi.db",False) cur2=sql1.ExecQuery("select * from dar") For i=0 To cur2.RowCount-1 cur2.Position=i ListView1.AddSingleLine(cur2.GetInt("id") &"|"&cur2.GetString("tarikh") &"|"&cur2.GetString("mosafer") &"|"&cur2.GetString("maghsad") &"|"&cur2.GetString("keraye") &"|"&cur2.GetString("com")) Next End Subلینک ارسال
