من قبلا تویه یه پروژه از لودبیتمپ سمپل استفاده کردم و درست اجرا میشد ولی اینبار نمیدونم چیشده
کدهام هم اینه
Sub show
Dim h As Int = 2%y
For i = 0 To Main.cur.RowCount - 1
Main.cur.Position = i
If Main.cur.GetInt("Type") = 0 Then
Dim lbl As Label
lbl.Initialize("")
lbl.Textcolor = Colors.White
lbl.Textsize = 17
lbl.Text = Main.cur.GetString("Value")
lbl.Typeface = Typeface.LoadFromAssets("b homa.ttf")
ScrollView1.Panel.AddView(lbl,5%X,h,90%x,0)
Dim su As StringUtils
lbl.Height = su.MeasureMultilineTextHeight(lbl,lbl.Text)
h = h + lbl.Height + 2%y
ScrollView1.panel.height = h
else if Main.cur.GetInt("Type") = 1 Then
Dim image1 As ImageView
image1.Initialize("")
image1.Bitmap = LoadBitmapSample(File.DirAssets,Main.cur.GetString("Value"),ScrollView1.Width,50%y)
image1.Gravity = Gravity.FILL
Dim be As BitmapExtended
be.Initialize("")
ScrollView1.panel.addview(image1,0,h,ScrollView1.Width,50%y)
h = h + 50%y + 2%y
ScrollView1.Panel.Height = h
mehrabmmp 528
بازم این مشکل پیدا شد
downsampling image due to lack of memory
downsampling image due to lack of memory : 10
downsampling image due to lack of memory : 2
downsampling image due to lack of memory : 4
کدهام هم اینه
Sub show Dim h As Int = 2%y For i = 0 To Main.cur.RowCount - 1 Main.cur.Position = i If Main.cur.GetInt("Type") = 0 Then Dim lbl As Label lbl.Initialize("") lbl.Textcolor = Colors.White lbl.Textsize = 17 lbl.Text = Main.cur.GetString("Value") lbl.Typeface = Typeface.LoadFromAssets("b homa.ttf") ScrollView1.Panel.AddView(lbl,5%X,h,90%x,0) Dim su As StringUtils lbl.Height = su.MeasureMultilineTextHeight(lbl,lbl.Text) h = h + lbl.Height + 2%y ScrollView1.panel.height = h else if Main.cur.GetInt("Type") = 1 Then Dim image1 As ImageView image1.Initialize("") image1.Bitmap = LoadBitmapSample(File.DirAssets,Main.cur.GetString("Value"),ScrollView1.Width,50%y) image1.Gravity = Gravity.FILL Dim be As BitmapExtended be.Initialize("") ScrollView1.panel.addview(image1,0,h,ScrollView1.Width,50%y) h = h + 50%y + 2%y ScrollView1.Panel.Height = h End If Next End Subلینک ارسال
