ObfuscatorMap.txt file created in Objects folder. Compiling layouts code. (0.03s) Generating R file. Error AndroidManifest.xml:94: error: Error: No resource found that matches the given name (at 'theme' with value '@style/PusheTransparent'). AndroidManifest.xml:98: error: Error: No resource found that matches the given name (at 'value' with value '@integer/google_play_services_version').
alivoll 17
سلام من وقتی میخوام منیفست سایت پوشه رو تو بیسیک بزارم موقع اجرار این ارور رو میده
B4A version: 5.80
Parsing code. (0.03s)
Compiling code. (0.13s)
