من ی تاپیک قبلا زدم که اخرش درست ب نتیجه نرسیدم بعدش خودم رفتم سراغش و تقریبا 80% کارا حل کردم فقط موندم چجوری فیلد fav را اپدیت کنم
ببینید کل کد به این شکل بود:
(Sub Activity_Create(FirstTime As Boolean
("Activity.LoadLayout("sv1
If File.Exists(File.DirInternal,"smslove.db")=False Then
File.copy(File.DirAssets,"smslove.db",File.DirInternal,"smslove.db")
SQL1.Initialize(File.DirInternal,"smslove.db",True)
cur1 = SQL1.ExecQuery("SELECT * FROM tbllove")
myfont = Typeface.LoadFromAssets("BTraffic.ttf")
For i=0 To cur1.RowCount-1
cur1.Position=i
text= cur1.GetString("smslove")
ScrollView1.Panel.Color = Colors.Transparent
Dim p1 As Panel
p1.Initialize("")
p1.LoadLayout("sms")
ScrollView1.Panel.AddView(p1,0,PanelHeight,100%x,100dip)
share.Tag = i
copy.Tag = i
ht=art(text,Label1,myfont,20)
Label1.TextColor=Colors.White
p1.Height=ht+70dip
PanelHeight=PanelHeight+ht+70dip
ScrollView1.Panel.Height=PanelHeight
Sub art(txt As String,leb As Label,font As Typeface,size As Int) As Float
Dim before,after As Float
Dim Obj1 As Reflector
leb.text=txt
leb.TextSize=size
leb.Gravity=Gravity.CENTER
leb.Left=leb.Left
leb.Typeface=font
ht = StrUtil.MeasureMultilineTextHeight(leb , txt)
Obj1.Target = leb
before = Obj1.RunMethod("getLineHeight")
Obj1.Target = leb
Obj1.RunMethod3("setLineSpacing", .10, "java.lang.float", 1.5, "java.lang.float")
Obj1.Target = leb
after = Obj1.RunMethod("getLineHeight")
ht = ((after * ht)/before)
leb.Height = ht
Return ht
Sub Activity_Resume
Sub share_Click
Dim cursor3 As Cursor
cursor3 = SQL1.ExecQuery("SELECT smslove FROM tbllove")
Dim btn2 As Button
btn2=Sender
cursor3.Position =btn2.Tag
Dim matnsms As Label
matnsms.Initialize("")
matnsms.text=cursor3.GetString("smslove")
cursor3.Close
StartActivity(sh.ShareText(matnsms.text,"اشتراک گذاری با :"))
Sub copy_Click
Dim something As BClipboard
Dim cursor2 As Cursor
cursor2 = SQL1.ExecQuery("SELECT smslove FROM tbllove")
Dim btn2 As Button
btn2=Sender
cursor2.Position =btn2.Tag
something.clrText
something.settext(cursor2.GetString("smslove"))
ToastMessageShow("متن در کلیپ بورد کپی شد",False)
cursor2.Close
من اومدم تو دکمه بوکمارک اینا نوشتم
Sub Btnlike_Click
Dim check As Int
check = cur1.Getint("fav")
If check = 0 Then
SQL1.ExecNonQuery("UPDATE tbllove SET fav = 1 WHERE id = "&cur1.GetInt("id"))
SQL1.IsInitialized
ToastMessageShow("به علاقه مندی ها اضافه شد",False)
قسمت فراخوانی پیام ها با fav=1 را حل کردم
با این کد وقتی دکمه بوکمارک را میزنم اخرین پیامم انگار فقط fav=1 میش
mahdig502 27
(Sub Activity_Create(FirstTime As Boolean ("Activity.LoadLayout("sv1 If File.Exists(File.DirInternal,"smslove.db")=False Then File.copy(File.DirAssets,"smslove.db",File.DirInternal,"smslove.db") End If SQL1.Initialize(File.DirInternal,"smslove.db",True) cur1 = SQL1.ExecQuery("SELECT * FROM tbllove") myfont = Typeface.LoadFromAssets("BTraffic.ttf") For i=0 To cur1.RowCount-1 cur1.Position=i text= cur1.GetString("smslove") ScrollView1.Panel.Color = Colors.Transparent Dim p1 As Panel p1.Initialize("") p1.LoadLayout("sms") ScrollView1.Panel.AddView(p1,0,PanelHeight,100%x,100dip) share.Tag = i copy.Tag = i ht=art(text,Label1,myfont,20) Label1.TextColor=Colors.White p1.Height=ht+70dip PanelHeight=PanelHeight+ht+70dip Next ScrollView1.Panel.Height=PanelHeight End Sub Sub art(txt As String,leb As Label,font As Typeface,size As Int) As Float Dim before,after As Float Dim Obj1 As Reflector leb.text=txt leb.TextSize=size leb.Gravity=Gravity.CENTER leb.Left=leb.Left leb.Typeface=font ht = StrUtil.MeasureMultilineTextHeight(leb , txt) Obj1.Target = leb before = Obj1.RunMethod("getLineHeight") Obj1.Target = leb Obj1.RunMethod3("setLineSpacing", .10, "java.lang.float", 1.5, "java.lang.float") Obj1.Target = leb after = Obj1.RunMethod("getLineHeight") ht = ((after * ht)/before) leb.Height = ht Return ht End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub share_Click Dim cursor3 As Cursor cursor3 = SQL1.ExecQuery("SELECT smslove FROM tbllove") Dim btn2 As Button btn2=Sender cursor3.Position =btn2.Tag Dim matnsms As Label matnsms.Initialize("") matnsms.text=cursor3.GetString("smslove") cursor3.Close StartActivity(sh.ShareText(matnsms.text,"اشتراک گذاری با :")) End Sub Sub copy_Click Dim something As BClipboard Dim cursor2 As Cursor cursor2 = SQL1.ExecQuery("SELECT smslove FROM tbllove") Dim btn2 As Button btn2=Sender cursor2.Position =btn2.Tag something.clrText something.settext(cursor2.GetString("smslove")) ToastMessageShow("متن در کلیپ بورد کپی شد",False) cursor2.Close End Subمن اومدم تو دکمه بوکمارک اینا نوشتم
Sub Btnlike_Click Dim check As Int check = cur1.Getint("fav") If check = 0 Then SQL1.ExecNonQuery("UPDATE tbllove SET fav = 1 WHERE id = "&cur1.GetInt("id")) SQL1.IsInitialized cur1 = SQL1.ExecQuery("SELECT * FROM tbllove") ToastMessageShow("به علاقه مندی ها اضافه شد",False) End If End Subقسمت فراخوانی پیام ها با fav=1 را حل کردم
دیگه دومی را نمیتونم بوکمارک کنم و این ارور میاد
مشکلش چیه؟
