مشکل در Style.xml پروژه
Cna
من یه پروژه رو داخل ایکلیپس ایمپورت کردم
ولی الان به فایل Style.xml داخل پوشه values ارور میگیره
متن ارورر هم اینجوریهDescription Resource Path Location Type
error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.AppCompat.Light.NoActionBar'. styles.xml /MainActivity/res/values line 4 Android AAPT Problem
error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.AppCompat.Dark.ActionBar'. styles.xml /MainActivity/res/values line 11 Android AAPT Problem
error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.AppCompat.Dark.ActionBar'. styles.xml /MainActivity/res/values line 15 Android AAPT Problem
error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.AppCompat.Light'. styles.xml /MainActivity/res/values line 17 Android AAPT Problem
error: Error: No resource found that matches the given name: attr 'actionMenuTextColor'. styles.xml /MainActivity/res/values line 12 Android AAPT Problem
error: Error: No resource found that matches the given name: attr 'colorAccent'. styles.xml /MainActivity/res/values line 8 Android AAPT Problem
error: Error: No resource found that matches the given name: attr 'colorPrimary'. styles.xml /MainActivity/res/values line 6 Android AAPT Problem
error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'. styles.xml /MainActivity/res/values line 7 Android AAPT Problem
که کلا 8 تا ارور میگیره
