اساتید من این کد دارم میخوام متن داخل lblbody اسکرول بشه از صبح تا حالا گیرشم لطف میکنید اگه راهنماییم کنید
#Region Activity Attributes #FullScreen: False
#IncludeTitle: False
#End Region
Sub Process_Globals
Dim sGroupName As String
Dim listSearch As List
Dim s1 As myDB
Dim l1 As List
Dim c1 As CustomListView
Private pnlparent As Panel
Private lblbody As Label
Private lbltitle As Label
Private imgbookmark As ImageView
Private imgshare As ImageView
Private imgsms As ImageView
Private imgemail As ImageView
Dim pre As AHPreferenceManager
Private lbltitle1 As Label
Dim sFontsize,sFontColor,sFontFamily As String
Activity.LoadLayout("frmsubgroup")
sFontsize = pre.GetString("fontsize")
If sFontsize.Length = 0 Then
sFontsize = 19
sFontColor = pre.GetString("fontcolor")
If sFontColor.Length = 0 Then
sFontColor = myLibrary.getColor("Black")
sFontColor = myLibrary.getColor(sFontColor)
sFontFamily = pre.GetString("fontfamily")
If sFontFamily.Length = 0 Then
sFontFamily = "byekan.ttf"
s1.Initialize
l1.Initialize
c1.Initialize(Me,"scroll")
lbltitle1.Typeface = Typeface.LoadFromAssets("byekan.ttf")
pnlparent.AddView(c1.AsView,0,53dip,100%x,100%y)
c1.bet = 30dip
If listSearch.IsInitialized = False OR sGroupName <> "" Then
l1 = s1.listsubGroup(sGroupName)
lbltitle1.Text = sGroupName
l1 = listSearch
lbltitle1.Text = "نتیجه جستجوی"
Log(l1.Size)
Dim sms1 As sSMS
sms1.Initialize
Try
sms1 = l1.Get(0)
Catch
Return
End Try
addItem(sms1)
Sub addItem(sms1 As sSMS)
Dim p1 As Panel
p1.Initialize("")
If sms1.sBody.Length > 200 Then
c1.Add(p1,360dip,"")
p1.LoadLayout("frmtemplatesms")
c1.Add(p1,240dip,"")
p1.LoadLayout("frmtemplatesms1")
lblbody.Text = sms1.sBody
lblbody.Typeface = Typeface.LoadFromAssets(sFontFamily)
lblbody.TextSize = sFontsize
lblbody.TextColor = sFontColor
Try
Catch
End Try
If sFontColor = "Red" Then
lblbody.TextColor = Colors.Red
Else If sFontColor = "Green" Then
lblbody.TextColor = Colors.Green
Else If sFontColor = "Blue" Then
lblbody.TextColor = Colors.Blue
Else If sFontColor = "Black" Then
lblbody.TextColor = Colors.Black
Else If sFontColor = "Yellow" Then
lblbody.TextColor = Colors.Yellow
imgbookmark.Tag = sms1.sID
imgemail.Tag = sms1.sBody
imgshare.Tag = sms1.sBody
imgsms.Tag = sms1.sBody
If myLibrary.checkBookmark(sms1.sID) = True Then
imgbookmark.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark_ok.png"))
Sub Activity_Resume
Sub imgbookmark_Click
Dim v1 As View
v1 = Sender
If myLibrary.bookmark(v1.Tag) = True Then
v1.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark_ok.png"))
ToastMessageShow("گزینه مورد نظر نشان شد",False)
v1.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark.png"))
ToastMessageShow("گزینه مورد نظر حذف شد",False)
Sub imgshare_Click
Dim v1 As View
v1 = Sender
myLibrary.ShareContent(v1.Tag,"اشتراک گذاری")
Sub imgsms_Click
Dim v1 As View
v1 = Sender
Dim a1 As InputDialog
a1.InputType = a1.INPUT_TYPE_PHONE
If a1.Show("شماره پیامک را وارد کنید","اشتراک","بفرست","انصراف","",Null) = DialogResponse.POSITIVE Then
If a1.Input.Length = 11 Then
myLibrary.SendSms(a1.Input,v1.Tag)
Sub imgemail_Click
Dim v1 As View
v1 = Sender
a1.InputType = a1.INPUT_TYPE_TEXT
If a1.Show("ادرس الکترونیکی را وارد کنید","اشتراک","بفرست","انصراف","",Null) = DialogResponse.POSITIVE Then
If a1.Input.Length > 7 Then
myLibrary.SendMail(a1.Input,v1.Tag,"موضوع جدید")
Sub btnback_Click
Activity.Finish
StartActivity(actGroup)
myLibrary.SetAnimation("file3","file4")
mashgholom 34
سلام دوستای گلم همگی خسته نباشید
#Region Activity Attributes #FullScreen: False #IncludeTitle: False #End Region Sub Process_Globals Dim sGroupName As String Dim listSearch As List End Sub Sub Globals Dim s1 As myDB Dim l1 As List Dim c1 As CustomListView Private pnlparent As Panel Private lblbody As Label Private lbltitle As Label Private imgbookmark As ImageView Private imgshare As ImageView Private imgsms As ImageView Private imgemail As ImageView Dim pre As AHPreferenceManager Private lbltitle1 As Label Dim sFontsize,sFontColor,sFontFamily As String End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("frmsubgroup") sFontsize = pre.GetString("fontsize") If sFontsize.Length = 0 Then sFontsize = 19 End If sFontColor = pre.GetString("fontcolor") If sFontColor.Length = 0 Then sFontColor = myLibrary.getColor("Black") Else sFontColor = myLibrary.getColor(sFontColor) End If sFontFamily = pre.GetString("fontfamily") If sFontFamily.Length = 0 Then sFontFamily = "byekan.ttf" End If s1.Initialize l1.Initialize c1.Initialize(Me,"scroll") lbltitle1.Typeface = Typeface.LoadFromAssets("byekan.ttf") pnlparent.AddView(c1.AsView,0,53dip,100%x,100%y) c1.bet = 30dip If listSearch.IsInitialized = False OR sGroupName <> "" Then l1 = s1.listsubGroup(sGroupName) lbltitle1.Text = sGroupName Else l1 = listSearch lbltitle1.Text = "نتیجه جستجوی" End If Log(l1.Size) Dim sms1 As sSMS sms1.Initialize Try sms1 = l1.Get(0) Catch Return End Try addItem(sms1) End Sub Sub addItem(sms1 As sSMS) Dim p1 As Panel p1.Initialize("") If sms1.sBody.Length > 200 Then c1.Add(p1,360dip,"") p1.LoadLayout("frmtemplatesms") Else c1.Add(p1,240dip,"") p1.LoadLayout("frmtemplatesms1") End If lblbody.Text = sms1.sBody lblbody.Typeface = Typeface.LoadFromAssets(sFontFamily) lblbody.TextSize = sFontsize lblbody.TextColor = sFontColor Try lblbody.TextSize = sFontsize Catch End Try If sFontColor = "Red" Then lblbody.TextColor = Colors.Red Else If sFontColor = "Green" Then lblbody.TextColor = Colors.Green Else If sFontColor = "Blue" Then lblbody.TextColor = Colors.Blue Else If sFontColor = "Black" Then lblbody.TextColor = Colors.Black Else If sFontColor = "Yellow" Then lblbody.TextColor = Colors.Yellow End If imgbookmark.Tag = sms1.sID imgemail.Tag = sms1.sBody imgshare.Tag = sms1.sBody imgsms.Tag = sms1.sBody If myLibrary.checkBookmark(sms1.sID) = True Then imgbookmark.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark_ok.png")) End If End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub imgbookmark_Click Dim v1 As View v1 = Sender If myLibrary.bookmark(v1.Tag) = True Then v1.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark_ok.png")) ToastMessageShow("گزینه مورد نظر نشان شد",False) Else v1.SetBackgroundImage(LoadBitmap(File.DirAssets,"bookmark.png")) ToastMessageShow("گزینه مورد نظر حذف شد",False) End If End Sub Sub imgshare_Click Dim v1 As View v1 = Sender myLibrary.ShareContent(v1.Tag,"اشتراک گذاری") End Sub Sub imgsms_Click Dim v1 As View v1 = Sender Dim a1 As InputDialog a1.InputType = a1.INPUT_TYPE_PHONE If a1.Show("شماره پیامک را وارد کنید","اشتراک","بفرست","انصراف","",Null) = DialogResponse.POSITIVE Then If a1.Input.Length = 11 Then myLibrary.SendSms(a1.Input,v1.Tag) End If End If End Sub Sub imgemail_Click Dim v1 As View v1 = Sender Dim a1 As InputDialog a1.InputType = a1.INPUT_TYPE_TEXT If a1.Show("ادرس الکترونیکی را وارد کنید","اشتراک","بفرست","انصراف","",Null) = DialogResponse.POSITIVE Then If a1.Input.Length > 7 Then myLibrary.SendMail(a1.Input,v1.Tag,"موضوع جدید") End If End If End Sub Sub btnback_Click Activity.Finish StartActivity(actGroup) myLibrary.SetAnimation("file3","file4") End Subلینک ارسال
