.خودم دو سه تاروش رفتم ولی اشتباه بود . از این دو کد برای اعمال تغییرات تو اکتیویتی ها استفاده میکنم
Dim size1 As Int
setChanges
Sub Activity_Resume
setChanges
Sub setChanges
Dim laelSize As Int = ASP.GetInt("size",14)
btn1.TextSize = laelSize
btn2.TextSize = laelSize
btn3.TextSize = laelSize
btn4.TextSize = laelSize
btn5.TextSize = laelSize
کدهایی که تو قسمت تنظیمات استفاده میکنم
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: False
#End Region
Dim font1 As String
Dim size1 As Int
Dim font As String
Dim color As String
Dim size As Int
Dim ASP As AriaSharedPreferences
Private Label1 As Label
Private RadioButton1 As RadioButton
Private RadioButton2 As RadioButton
Private RadioButton3 As RadioButton
Private Label2 As Label
Private SeekBar1 As SeekBar
Private Label3 As Label
Private btn_save As Button
Private Label_fasele1 As Label
Private Label_fasele2 As Label
Private Label4 As Label
Private Label5 As Label
Activity.LoadLayout("setting")
If size<14 Then
Label4.Text=14
SeekBar1.Value=14
RadioButton1.Typeface=Typeface.LoadFromAssets("rezvan.ttf")
RadioButton2.Typeface=Typeface.LoadFromAssets("byekan.ttf")
RadioButton3.Typeface=Typeface.LoadFromAssets("bnazanin.ttf")
setChanges
Sub Activity_Resume
setChanges
Sub Activity_KeyUp (KeyCode As Int) As Boolean
StartActivity(Main)
Sub RadioButton1_CheckedChange(Checked As Boolean)
If RadioButton1.Checked=True Then
font="yekan"
Label5.Typeface=Typeface.LoadFromAssets("rezvan.ttf")
Sub RadioButton2_CheckedChange(Checked As Boolean)
If RadioButton2.Checked=True Then
font="byekan"
Label5.Typeface=Typeface.LoadFromAssets("byekan.ttf")
Sub RadioButton3_CheckedChange(Checked As Boolean)
If RadioButton3.Checked=True Then
font="bnazanin"
Label5.Typeface=Typeface.LoadFromAssets("bnazanin.ttf")
Sub btn_save_Click
If font="" Then
ToastMessageShow("لطفا متن مورد نظر خود را انتخاب کنید",False)
Else If size<14 Then
ToastMessageShow("لطفا اندازه متن را انتخاب کنید",False)
font1=font
size1=size
ToastMessageShow("تنظیمات انجام شد",False)
StartActivity("Main")
ASP.SaveInt("size", size1)
ASP.SaveString("font","font1")
Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean)
SeekBar1.Value=Value
size=Value
Label4.Text=Value
Label5.TextSize=Value
Sub setChanges
btn_save.TextSize = laelSize
Label1.TextSize = laelSize
Label2.TextSize = laelSize
Label3.TextSize = laelSize
ولی فراخوانی فونت رو بلد نیستم .ممنون میشم دوستان کمک کنن
hakan22 39
سلام خدمت دوستان .
با استفاده از کتابخانه زیر خیلی راحت میشه سایز رو تغییر داد. برای تغییر فونت چگونه باید عمل کنم؟
http://answercenter.ir/topic/9955-%D8%B0%D8%AE%DB%8C%D8%B1%D9%87-%D8%A7%D9%86%D9%88%D8%A7%D8%B9-%D8%A7%D8%B7%D9%84%D8%A7%D8%B9%D8%A7%D8%AA-%D8%A8%D9%87-%D8%B5%D9%88%D8%B1%D8%AA-%D8%A7%D8%B3%D8%AA%D8%A7%D9%86%D8%AF%D8%A7%D8%B1%D8%AF-%D8%AE%D9%88%D8%AF-%D8%A7%D9%86%D8%AF%D8%B1%D9%88/
