من سورسی که تو آموزش App Compact بود رو ران میکنم مشکلی نداره و هم کامپایل میشه و هم اجرا
اما برنامه خودم ارور میده
این از لوگ
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.phoneplus.ramezanyar/com.phoneplus.ramezanyar.main}: android.util.AndroidRuntimeException: requestFeature() must be called before adding content
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2416)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2476)
at android.app.ActivityThread.-wrap11(ActivityThread.java)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1344)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:148)
at android.app.ActivityThread.main(ActivityThread.java:5422)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:726)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616)
Caused by: android.util.AndroidRuntimeException: requestFeature() must be called before adding content
at com.android.internal.policy.PhoneWindow.requestFeature(PhoneWindow.java:319)
at com.phoneplus.ramezanyar.main.onCreate(main.java:50)
at android.app.Activity.performCreate(Activity.java:6251)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1107)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2369)
... 9 more
این هم سورس
#Region Project Attributes
#ApplicationLabel: رمضان یار
#VersionCode: 1
#VersionName: 1
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: false
#End Region
#AdditionalJar: android-support-v7-appcompat
#AdditionalRes: ..\resource
#AdditionalRes: C:\Android\b4a_appcompat, de.amberhome.objects.appcompat
#AdditionalRes: C:\Android\support\support\v7\appcompat\res, android.support.v7.appcompat
#Extends: android.support.v7.app.ActionBarActivity
Private topbt As Button
Private nbt As Button
Activity.LoadLayout("main")
Sub Activity_Resume
Sub nbt_Click
StartActivity(namaz)
این هم منیفست
'See this link for for more information: http://www.b4x.com/forum/showthread.php?p=78136
AddManifestText(
<uses-sdk android:minSdkVersion="5" android:targetSdkVersion="19"/>
android:normalScreens="true"
android:smallScreens="true"
android:anyDensity="true"/>)
SetApplicationAttribute(android:theme, "@style/MyAppTheme")
'SetApplicationAttribute(android:theme, "@style/Theme.AppCompat")
pourya-man 33
این از لوگ
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.phoneplus.ramezanyar/com.phoneplus.ramezanyar.main}: android.util.AndroidRuntimeException: requestFeature() must be called before adding content at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2416) at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2476) at android.app.ActivityThread.-wrap11(ActivityThread.java) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1344) at android.os.Handler.dispatchMessage(Handler.java:102) at android.os.Looper.loop(Looper.java:148) at android.app.ActivityThread.main(ActivityThread.java:5422) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:726) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616) Caused by: android.util.AndroidRuntimeException: requestFeature() must be called before adding content at com.android.internal.policy.PhoneWindow.requestFeature(PhoneWindow.java:319) at com.phoneplus.ramezanyar.main.onCreate(main.java:50) at android.app.Activity.performCreate(Activity.java:6251) at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1107) at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2369) ... 9 moreاین هم سورس
#Region Project Attributes #ApplicationLabel: رمضان یار #VersionCode: 1 #VersionName: 1 #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: false #End Region #AdditionalJar: android-support-v7-appcompat #AdditionalRes: ..\resource #AdditionalRes: C:\Android\b4a_appcompat, de.amberhome.objects.appcompat #AdditionalRes: C:\Android\support\support\v7\appcompat\res, android.support.v7.appcompat #Extends: android.support.v7.app.ActionBarActivity Sub Process_Globals End Sub Sub Globals Private topbt As Button Private nbt As Button End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("main") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub nbt_Click StartActivity(namaz) End Subاین هم منیفست
تو دیزاینر از کاستوم ویو یه باتن فلت گذاشتم
