من میخوام بگم که اگر عکس در دیتابیس null بود عکس را نشان ندهد ، برای متنش رو تونستم ولی عکس رو هر کار میکنم نمیشه
For i=0 To count
For i=0 To cursor1.RowCount-1
cursor1.Position = i
p.Initialize("Panel1")
p.Color = Colors.Transparent
ScrollView1.Panel.AddView(p,5dip,top,Activity.Width-10dip,-2)
aks.Initialize("AKS1")
Dim bytes() As Byte
bytes=cursor1.GetBlob("aks")
Dim input As InputStream
input.InitializeFromBytesArray(bytes,0,bytes.Length)
Dim b As Bitmap
b.Initialize2(input)
input.Close
Dim bg As BitmapDrawable
bg.Initialize(b)
aks.Background=bg
matnn.Initialize("Matnn")
matnn.Text = cursor1.GetString("matn")
If cursor1.GetString("matn")=Null Then
matnn.Text = ""
p.AddView(aks,10dip,matnn.Height,Activity.Width-20dip,Activity.Width-80dip)
majid22012 2
For i=0 To count For i=0 To cursor1.RowCount-1 cursor1.Position = i p.Initialize("Panel1") p.Color = Colors.Transparent ScrollView1.Panel.AddView(p,5dip,top,Activity.Width-10dip,-2) aks.Initialize("AKS1") Dim bytes() As Byte bytes=cursor1.GetBlob("aks") Dim input As InputStream input.InitializeFromBytesArray(bytes,0,bytes.Length) Dim b As Bitmap b.Initialize2(input) input.Close Dim bg As BitmapDrawable bg.Initialize(b) aks.Background=bg matnn.Initialize("Matnn") matnn.Text = cursor1.GetString("matn") If cursor1.GetString("matn")=Null Then matnn.Text = "" Else matnn.Text = cursor1.GetString("matn") End If p.AddView(aks,10dip,matnn.Height,Activity.Width-20dip,Activity.Width-80dip)با تشکر
