با سلام من می خواستم در بخش خرید یک لیست ویو گزاشتم
و در ساب ایتم کلیک اینجوری نوشتم
Sub listv_ItemClick (Position As Int, Value As Object)
If Pardakht = True Then
Select Value
Case "Remove_Ads"
Msgbox("با تشکر از خرید شما حذف تبلغات یک بار انجام شده است","حذف تبلیغات")
Case "1000"
payment.RequestPayment("1000","inapp","1000")
Case "5000"
payment.RequestPayment("5000","inapp","5000")
Case "6000"
payment.RequestPayment("6000","inapp","6000")
If File.Exists(File.DirInternal,"ads.txt") Or File.Exists(File.DirDefaultExternal,"ads.txt") = True Then
Case "2000"
payment.RequestPayment("200","inapp","2000")
Case "3000"
payment.RequestPayment("300","inapp","3000")
Case "4000"
payment.RequestPayment("400","inapp","4000")
Case "2000"
payment.RequestPayment("2000","inapp","2000")
Case "3000"
payment.RequestPayment("3000","inapp","3000") 'در این خط ارور میده
Case "4000"
payment.RequestPayment("4000","inapp","4000")
End Select
Msgbox("خطایی رخ داد لطفا بعدا تلاش کنید.","خطا")
Return
basicofdata 99
Sub listv_ItemClick (Position As Int, Value As Object) If Pardakht = True Then Select Value Case "Remove_Ads" Msgbox("با تشکر از خرید شما حذف تبلغات یک بار انجام شده است","حذف تبلیغات") Case "1000" payment.RequestPayment("1000","inapp","1000") Case "5000" payment.RequestPayment("5000","inapp","5000") Case "6000" payment.RequestPayment("6000","inapp","6000") If File.Exists(File.DirInternal,"ads.txt") Or File.Exists(File.DirDefaultExternal,"ads.txt") = True Then Case "2000" payment.RequestPayment("200","inapp","2000") Case "3000" payment.RequestPayment("300","inapp","3000") Case "4000" payment.RequestPayment("400","inapp","4000") Else Case "2000" payment.RequestPayment("2000","inapp","2000") Case "3000" payment.RequestPayment("3000","inapp","3000") 'در این خط ارور میده Case "4000" payment.RequestPayment("4000","inapp","4000") End If End Select Else Msgbox("خطایی رخ داد لطفا بعدا تلاش کنید.","خطا") Return End If End Subایا جای ایف اونجا هست یا نه
ممنون راهنمایی کنید
