علت ارور در متریال
sajjadrastin
ارور زیر رو چجوری حل کنم؟
B4A version: 5.80
Parsing code.    (0.01s)
Compiling code.    (0.21s)
ObfuscatorMap.txt file created in Objects folder.
Compiling layouts code.    (0.06s)
Generating R file.    Error
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:75: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:79: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.CloseMode'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:83: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.Overflow'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:25: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabView'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:29: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabView'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:33: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabText'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:37: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:65: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Title'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:69: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Subtitle'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:45: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Menu'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:49: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:53: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:57: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:61: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:184: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar.Horizontal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:188: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:113: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:115: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner.Underlined'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:117: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:110: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.DropDownItem.Spinner'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:107: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView.DropDown'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:123: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:128: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListPopupWindow'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:140: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:145: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:131: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.PopupMenu'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:134: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.PopupMenu'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:148: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:152: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:156: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:160: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:166: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Title'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:170: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Subtitle'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:174: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.AutoCompleteTextView'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:93: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Toolbar.Button.Navigation'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:97: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:101: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:62: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:176: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.RatingBar'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:178: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:180: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Small'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:192: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.TextView.SpinnerItem'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base.xml:194: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.TextView.SpinnerItem'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v12\styles_base.xml:21: error: Error retrieving parent for item: No resource found that matches the given name 'Base.V7.Widget.AppCompat.EditText'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v12\styles_base.xml:27: error: Error retrieving parent for item: No resource found that matches the given name 'Base.V7.Widget.AppCompat.AutoCompleteTextView'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v23\styles_base.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Colored'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:22: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display4'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:24: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display3'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display2'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:28: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display1'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:30: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Headline'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:32: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Title'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:34: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Subhead'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body2'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:38: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body1'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:40: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Caption'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:42: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Menu'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:60: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:46: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:48: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:50: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:52: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:54: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:56: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:58: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v23\styles_base_text.xml:19: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Inverse'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:31: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Dialog'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light.Dialog'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:351: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:29: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:358: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:37: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:365: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:45: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v11\themes_base.xml:372: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v14\themes_base.xml:53: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:202: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:204: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:203: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:217: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Light'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:221: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:220: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:207: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:211: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:210: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:227: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.ActionBar'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:231: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:230: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:234: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark.ActionBar'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:239: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:238: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:81: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:83: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:84: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:82: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:79: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:80: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:118: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:120: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:121: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:119: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:116: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:117: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:155: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:157: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:158: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:156: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:153: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:154: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:192: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:194: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:195: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:193: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:190: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v21\themes_base.xml:191: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v23\themes_base.xml:27: error: Error: No resource found that matches the given name: attr 'controlBackground'.
c:\program files\android\android-sdk\support\support\v7\appcompat\res\values-v23\themes_base.xml:34: error: Error: No resource found that matches the given name: attr 'controlBackground'.
از b4a_appcompat استفاده میکنم
و فایل ها رو از http://answercenter.ir/topic/6097-%D8%A7%D9%85%D9%88%D8%B2%D8%B4-%D8%AA%D8%B5%D9%88%DB%8C%D8%B1%DB%8C-%D8%A7%D8%B3%D8%AA%D9%81%D8%A7%D8%AF%D9%87-%D8%A7%D8%B2-%D8%B3%D9%88%D8%B1%D8%B3-%D9%87%D8%A7%DB%8C-appcombat-%D8%B7%D8%B1%D8%AD-%D9%85%D8%AA%D8%B1%DB%8C%D8%A7%D9%84/ دانلود کردم.
لطفا کمک کنید.
مشکل قبلیم حل شد  ولی بعد از کامپایل و نصب برنامه و لاگ ارور میده و برنامه بسته میشه:
ارور:
java.lang.NoSuchFieldError: android.support.v7.appcompat.R$styleable.AppCompatTheme
چک کنین ببینین توی منفیست این خط کد رو نوشتین؟
SetApplicationAttribute(android:theme, "@style/MyAppTheme")
بله  تو ماینفست هست
با سلام خدمت دوست عزیز
یه تجربه ای داشتم در مورد متریال شاید مشکل شما را حل کند
اولین بار که از متریال استفاده کردم همیشه موقع کامپایل ارور میداد در صورتیکه همه چیز درست بود
تا اینکه در یک سایت آموزشی خواندم که پوشه Android SDK را بطور کامل حذف و دوباره در یک پوشه ای بنام Android بطور مستقیم(نه در پوشه  Program) در درایو C نصب کنید.
از یک سایت معروف ایرانی (نمی خوام اسم بیارم تا تبلیغ نشه خودتون جستجو کنید) Android SDK را دانلود کردم
موقع اکستراک حدود 7 گیک میشه
آنرا در درایو C کپی کردم و درست شد.
این تجربه ای که گفتم حدود سه هفته درگیرش بودم یعنی منظورم اینکه متریال در اول این دردسرها را دارد تا اینکه آنرا یاد بگیری.
امیدوارم کمک کننده باشد
موفق باشی.
موفق باشی.
لطفا اون فایل Android SDK رو برام بفرستید یا در تاپیک قرار بدید.
اخه چند بار و روی چند پروژه دیگه تست کردم و ادرس فایل را هم عوض کردم و حتی اون پوشه و فایل ها رو هم نسخه جدیدش رو نصب کردم اما همش همین ارور رو میده !!!
ممنون از کمکتون
