#Region Project Attributes
#ApplicationLabel: تـازه هـا
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: False
#End Region
Dim Parser As SaxParser
Dim HttpClient1 As HttpClient
Dim Hr As HttpRequest
Dim Str1 As String
Private Label1 As Label
Dim Font As Typeface
Dim GetListView As ListView
Dim Title, Link, PubDate, Description As String
Dim BufferText As String
Dim NewFeed As String
Activity.LoadLayout("1")
Font = Typeface.LoadFromAssets("Soltan.ttf")
Label1.Typeface = Font
GetListView.Width = 100%x
GetListView.Height = 100%y
Parser.Initialize
HttpClient1.Initialize("HttpClient1")
Hr.InitializeGet("http://www.alisz.ir/rss.xml")
HttpClient1.Execute(Hr, 1)
Sub GetListView_ItemClick(Position As Int, Value As Object)
Str1 = Value
StartActivity(Matn)
Sub HttpClient1_ResponseSuccess(Response As HttpResponse, TaskId As Int)
ProgressDialogShow("لطفا صبر کنید")
Response.GetAsynchronously("GetGetListView", File.OpenOutput(File.DirDefaultExternal, "RSS.xml", False), True, TaskId)
Sub HttpClient1_ResponseError(Response As HttpResponse, Reason As String, StatusCode As Int, TaskId As Int)
If Response <> Null Then
Msgbox("Error: " & Response.GetString("UTF8"), "Connection Error")
Response.Release
Sub GetGetListView_StreamFinish(Success As Boolean, TaskId As Int)
ProgressDialogHide
If Success = False Then
Msgbox(LastException.Message, "Error")
Return
Dim In As InputStream
In = File.OpenInput(File.DirDefaultExternal, "RSS.xml")
Parser.Parse(In, "Parser")
In.Close
NewFeed = File.ReadString(File.DirDefaultExternal, "RSS.xml")
Sub Parser_StartElement(Uri As String, Name As String, Attributes As Attributes)
Sub Parser_EndElement(Uri As String, Name As String, Text As StringBuilder)
If Parser.Parents.IndexOf("item") > -1 Then
If Name = "title" Then
Title = Text.ToString
Else If Name = "link" Then
Link = Text.ToString
Else If Name = "pubdate" Then
PubDate = Text.ToString
Else If Name = "description" Then
Description = Text.ToString
If Name = "item" Then
GetListView.AddSingleLine2(Title, Description)
Dim Label2 As Label
Label2 = GetListView.SingleLineLayout.Label
Label2.TextSize = 15
Label2.Left = Label2.width - 5dip
Label2.TextColor = Colors.White
Sub Activity_Resume
من میخوام تو لیست ویو یه لیست ویوی دو خطی همراه عکس درست بشه که تو خط اول <title> تو خط دوم <description> برای عکس <img> رو از فایل xml روی سایت بخونه و وقتی روش کلیک شد متناسب با آیتیمی که کلیک شد <link> مربوطه رو باز کنه ، لطفنکمک کنید
cloner01001 38
دوستان من با این کد یه برنامه rss خوان ساختم
#Region Project Attributes #ApplicationLabel: تـازه هـا #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: False #End Region Sub Process_Globals Dim Parser As SaxParser Dim HttpClient1 As HttpClient Dim Hr As HttpRequest Dim Str1 As String End Sub Sub Globals Private Label1 As Label Dim Font As Typeface Dim GetListView As ListView Dim Title, Link, PubDate, Description As String Dim BufferText As String Dim NewFeed As String End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("1") Font = Typeface.LoadFromAssets("Soltan.ttf") Label1.Typeface = Font GetListView.Width = 100%x GetListView.Height = 100%y Parser.Initialize HttpClient1.Initialize("HttpClient1") Hr.InitializeGet("http://www.alisz.ir/rss.xml") HttpClient1.Execute(Hr, 1) End Sub Sub GetListView_ItemClick(Position As Int, Value As Object) Str1 = Value StartActivity(Matn) End Sub Sub HttpClient1_ResponseSuccess(Response As HttpResponse, TaskId As Int) ProgressDialogShow("لطفا صبر کنید") Response.GetAsynchronously("GetGetListView", File.OpenOutput(File.DirDefaultExternal, "RSS.xml", False), True, TaskId) End Sub Sub HttpClient1_ResponseError(Response As HttpResponse, Reason As String, StatusCode As Int, TaskId As Int) If Response <> Null Then Msgbox("Error: " & Response.GetString("UTF8"), "Connection Error") Response.Release End If End Sub Sub GetGetListView_StreamFinish(Success As Boolean, TaskId As Int) ProgressDialogHide If Success = False Then Msgbox(LastException.Message, "Error") Return End If Dim In As InputStream In = File.OpenInput(File.DirDefaultExternal, "RSS.xml") Parser.Parse(In, "Parser") In.Close NewFeed = File.ReadString(File.DirDefaultExternal, "RSS.xml") End Sub Sub Parser_StartElement(Uri As String, Name As String, Attributes As Attributes) End Sub Sub Parser_EndElement(Uri As String, Name As String, Text As StringBuilder) If Parser.Parents.IndexOf("item") > -1 Then If Name = "title" Then Title = Text.ToString Else If Name = "link" Then Link = Text.ToString Else If Name = "pubdate" Then PubDate = Text.ToString Else If Name = "description" Then Description = Text.ToString End If End If If Name = "item" Then GetListView.AddSingleLine2(Title, Description) Dim Label2 As Label Label2 = GetListView.SingleLineLayout.Label Label2.TextSize = 15 Label2.Left = Label2.width - 5dip Label2.TextColor = Colors.White End If End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subسورس rss من به این صورت هست:
