آپلود تصویر از اندروید به سرور php
coco
یه مشکل برام پیش اومده
میخوام از سمت اندروید یه عکس آپلود کنم
با کتابخانه OkHttp
اما هر کار میکنم نمیشه :(
خیلی هم عجله دارم :/
لطفا راهنمایی کنین!
همینطور بخش php :DD:
سمت php
  <?php
        $file_path = "uploads/";
        $file_path = $file_path . basename( $_FILES['uploaded_file']['name']);
        if(move_uploaded_file($_FILES['uploaded_file']['tmp_name'], $file_path)) {
            echo "success ". $headers["uploaded_file"];
        } else{
            echo "fail";
یه پوشه به اسم uploads هم کنار php قرار بده،
این هم class آپلودر :
 class Uploader extends AsyncTask<Void, Void, String> {
        @Override
        protected String doInBackground(Void... strings) {
            try {
                String Url = "AddressFilePHP";
                File file = new File("AddressFile");
                HttpURLConnection conn = (HttpURLConnection) new URL(Url).openConnection();
                FileInputStream fileInputStream = new FileInputStream(file);
                int maxBufferSize = 1 * 1024 * 1024;
                String lineEnd = "\r\n";
                String twoHyphens = "--";
                String boundary = "*****";
                conn.setDoInput(true);
                conn.setDoOutput(true);
                conn.setUseCaches(false);
                conn.setRequestMethod("POST");
                conn.setRequestProperty("Connection", "Keep-Alive");
                conn.setRequestProperty("ENCTYPE", "multipart/form-data");
                conn.setRequestProperty("Content-Type", "multipart/form-data;boundary=" + boundary);
                conn.setRequestProperty("uploaded_file", file.getName());
                final DataOutputStream dos = new DataOutputStream(conn.getOutputStream());
                dos.writeBytes(twoHyphens + boundary + lineEnd);
                dos.writeBytes("Content-Disposition: form-data; name=\"uploaded_file\";filename=\""
                        + file.getName() + "\"" + lineEnd);
                dos.writeBytes(lineEnd);
                int bytesAvailable = fileInputStream.available();
                int bufferSize = Math.min(bytesAvailable, maxBufferSize);
                byte[] buffer = new byte[bufferSize];
                // read file and write it into form...
                int bytesRead = fileInputStream.read(buffer, 0, bufferSize);
                while (bytesRead > 0) {
                    dos.write(buffer, 0, bufferSize);
                dos.writeBytes(twoHyphens + boundary + twoHyphens + lineEnd);
                BufferedReader r = new BufferedReader(
                        new InputStreamReader(conn.getInputStream(), "UTF-8"));
                String content = "";
                String line;
                while ((line = r.readLine()) != null) {
                    content += line + "\n";
                return content;
            }catch (Exception e){
                Log.v("UploaderError", e.getMessage());
                return "fail " +  e.getMessage();
        @Override
        protected void onPostExecute(String s) {
            super.onPostExecute(s);
            if (s.startsWith("fail")){
                Log.e("UploaderError", s);
            }else{
                Log.v("UploaderError", "Upload Anjam Shod |||| " + s);
