من میخوام سورس متریال دیالوگ رو کامپایل کنم این ارور رو میده
B4A version: 6.00
Parsing code. (0.01s)
Compiling code. (0.02s)
Compiling layouts code. (0.00s)
Organizing libraries. (0.00s)
Generating R file. Error
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:5: error: Attribute "md_divider" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:8: error: Attribute "md_dark_theme" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:9: error: Attribute "md_background_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:11: error: Attribute "md_icon" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:12: error: Attribute "md_icon_max_size" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:13: error: Attribute "md_icon_limit_icon_to_default_size" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:15: error: Attribute "md_title_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:16: error: Attribute "md_content_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:18: error: Attribute "md_positive_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:19: error: Attribute "md_neutral_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:20: error: Attribute "md_negative_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:21: error: Attribute "md_widget_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:23: error: Attribute "md_item_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:24: error: Attribute "md_divider_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:25: error: Attribute "md_list_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:27: error: Attribute "md_btn_stacked_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:28: error: Attribute "md_btn_positive_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:29: error: Attribute "md_btn_neutral_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:30: error: Attribute "md_btn_negative_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:32: error: Attribute "md_title_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:38: error: Attribute "md_content_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:44: error: Attribute "md_btnstacked_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:50: error: Attribute "md_items_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:56: error: Attribute "md_buttons_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:63: error: Attribute "md_reduce_padding_no_title_no_buttons" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:66: error: Attribute "md_medium_font" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:67: error: Attribute "md_regular_font" has already been defined
amir00700 66
