مشکل در کامپایل متریال دیالوگ
amir00700
من میخوام سورس متریال دیالوگ رو کامپایل کنم این ارور رو میده
B4A version: 6.00
Parsing code.    (0.01s)
Compiling code.    (0.02s)
Compiling layouts code.    (0.00s)
Generating R file.    Error
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:5: error: Attribute "md_divider" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:8: error: Attribute "md_dark_theme" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:9: error: Attribute "md_background_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:11: error: Attribute "md_icon" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:12: error: Attribute "md_icon_max_size" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:13: error: Attribute "md_icon_limit_icon_to_default_size" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:15: error: Attribute "md_title_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:16: error: Attribute "md_content_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:18: error: Attribute "md_positive_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:19: error: Attribute "md_neutral_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:20: error: Attribute "md_negative_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:21: error: Attribute "md_widget_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:23: error: Attribute "md_item_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:24: error: Attribute "md_divider_color" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:25: error: Attribute "md_list_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:27: error: Attribute "md_btn_stacked_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:28: error: Attribute "md_btn_positive_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:29: error: Attribute "md_btn_neutral_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:30: error: Attribute "md_btn_negative_selector" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:32: error: Attribute "md_title_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:38: error: Attribute "md_content_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:44: error: Attribute "md_btnstacked_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:50: error: Attribute "md_items_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:56: error: Attribute "md_buttons_gravity" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:63: error: Attribute "md_reduce_padding_no_title_no_buttons" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:66: error: Attribute "md_medium_font" has already been defined
c:\b4a-answercenter\resource\materialdialog\additional_res\msdialog\res\values\attrs.xml:67: error: Attribute "md_regular_font" has already been defined
چون داخل بیسیک 6 مستقیم منابع اد میشن این داره به شما میگه یکبار این منابع اد شده اند برید داخل ریسورس های متریال دیالوگ همین خط های xml رو که شمارشون رو میگه پاک کنید درست میشه .
