اساتید من یه کتابی دارم که متنو از دیتابیس میگیره اما بعضی وقتا متنو خالی میاره بعضی وقتا هم میاره
مشکل از چی میتونه باشه؟
Dim cur As Cursor
cur = Home.SQL1.ExecQuery("SELECT * FROM mytable WHERE id ="&Home.meghdar)
matn.Initialize("")
matn.Gravity = Gravity.RIGHT
matn..SingleLineLayout.Label.TextColor = Colors.Black
ScrollView1.Panel.AddView(matn,0,0,95%X,100%y)
ts.Initialize
For i = 0 To cur.RowCount-1
cur.Position = i
matn.Text = cur.GetString("matn")
If File.Exists(File.DirInternal,"database.db") = False Then
File.Copy(File.DirAssets,"database.db",File.DirInternal,"database.db")
If SQL1.IsInitialized = False Then
SQL1.Initialize(File.DirInternal,"database.db",True)
Dim cur As Cursor
cur = SQL1.ExecQuery("SELECT * FROM mytable")
cur.Position = i
List_matlab.AddSingleLine2(cur.GetString("list"),cur.GetInt("id"))
cur.Close
bahman 165
Dim cur As Cursor cur = Home.SQL1.ExecQuery("SELECT * FROM mytable WHERE id ="&Home.meghdar) matn.Initialize("") matn.Gravity = Gravity.RIGHT matn..SingleLineLayout.Label.TextColor = Colors.Black ScrollView1.Panel.AddView(matn,0,0,95%X,100%y) ts.Initialize For i = 0 To cur.RowCount-1 cur.Position = i matn.Text = cur.GetString("matn") NextIf File.Exists(File.DirInternal,"database.db") = False Then File.Copy(File.DirAssets,"database.db",File.DirInternal,"database.db") End If If SQL1.IsInitialized = False Then SQL1.Initialize(File.DirInternal,"database.db",True) End If Dim cur As Cursor cur = SQL1.ExecQuery("SELECT * FROM mytable") For i = 0 To cur.RowCount-1 cur.Position = i List_matlab.AddSingleLine2(cur.GetString("list"),cur.GetInt("id")) Next cur.Close End Subلینک ارسال
