مشکل در appcompat3(ریسورس ها)
amirmahdi3744
سلام خسته نباشید.من دارم از نسخه 6 بیسیک و نسخه 3.2 appcompat استفاده می کنم.توی مرحله ریسورس ها موندم. این کد های منه:
'#AdditionalRes:C:\Users\amirmahdi\Downloads\Telegram Desktop\support\v7\cardview\res
'#AdditionalRes: ..\resource
	#AdditionalRes:C:\Users\amirmahdi\Desktop\basic4andoid\Resource\MSRes
#Extends: android.support.v7.app.ActionBarActivity
''////////basic4android.org////
#Region  Activity Attributes
	#FullScreen: False
	#IncludeTitle: True
#End Region
Sub Process_Globals
	Private Panel1 As Panel
	Private ActionBar As ACToolBarLight
Dim ph As Phone
Dim Flash As AdvancedCamera
	Dim ABHelper As ACActionBar
		Dim AC As AppCompat
	Private Label1 As Label
	Dim AC As AppCompat
	Private pContent As Panel
	Private EditText1 As EditText
	Private ACSwitch1 As ACSwitch
	Private lablech As Label
	Activity.LoadLayout("main")
	ActionBar.SetAsActionBar
	ActionBar.Title = "Telegram User Searcher"
	ActionBar.Color = Colors.RGB(90,149,255)
	pContent.LoadLayout("main")
	ABHelper.Initialize
		ABHelper.ShowUpIndicator = True
	Log("ActionBar Height: " & (AC.GetMaterialActionBarHeight / DipToCurrent(1)))
	Activity.AddMenuItem("ارتباط با ما", "over1")
	Activity.AddMenuItem("در باره ما", "over2")
	Activity.AddMenuItem("خروج", "over3")
	Flash.Initialize(Panel1, "Flash")
	Panel1.Visible=False
Sub over1_Click
StartActivity(email)
Sub over2_Click
Dim elyas As PhoneIntents
StartActivity(elyas.OpenBrowser("http://answercenter.ir"))
Sub over3_Click
ExitApplication
Sub Activity_Resume
Sub cbABVisible_CheckedChange(Checked As Boolean)
	If Checked Then
		ActionBar.SetLayoutAnimated(200, 0, 0, 100%x, AC.GetMaterialActionBarHeight)
		ActionBar.SetVisibleAnimated(200, True)
		pContent.SetLayoutAnimated(200, 0, AC.GetMaterialActionBarHeight, 100%x, 100%y - AC.GetMaterialActionBarHeight)
		ActionBar.SetLayoutAnimated(200, 0, 0, 100%x, 1dip)
		ActionBar.SetVisibleAnimated(200, False)
		pContent.SetLayoutAnimated(200, 0, 0, 100%x, 100%y)
این هم ارور برنامه است که هر کاری می کنم همین ارور رو میده:Capture.PNG
اینهم منیفست:
'See this link for for more information: http://www.basic4ppc.com/forum/showthread.php?p=78136
AddManifestText(
<uses-sdk android:minSdkVersion="7" android:targetSdkVersion="21"/>
    android:normalScreens="true"
    android:smallScreens="true"
    android:anyDensity="true"/>)
'End of default text.
SetApplicationAttribute(android:theme, "@style/MyAppTheme")
CreateResource(values, theme.xml,
<resources>
    <style name="MyAppTheme" parent="Theme.AppCompat.Light.NoActionBar">
        <item name="colorPrimary">#0098FF</item>
        <item name="colorPrimaryDark">#007CF5</item>
        <item name="colorAccent">#AAAA00</item>
        <item name="windowNoTitle">true</item>
        '<item name="windowActionBar">false</item>
    </style>
</resources>
AddPermission(android.permission.WRITE_SETTINGS)
دیگه مونده ام چکار کنم خواهش می کنم کمکم کنید
سلام از api نسخه 22 یا 23 استفاده کنید.
api من هم 23 هست یعنی اندروید 6 .دوستان میشه راهنمایی کنید
فک نکنم این خطا ربطی به ریسورس های اپ کامپت داشته باشه.
این خطای Null  بودن هستش که میتونیه از هر چیزی باشه.
با Log  کدهاتون رو چک کنید، رویداد ها و توابع رو چک کنید.
