باز هم مشکل در متریال !!!
mahdiamiria
در طراحی متریال
هنگام کمپایل کردن برنامه با پیام زیر روبرو میشم:
Packaging files.    Error
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_btn_switch_to_on_mtrl_00001.9.png malformed.
       Ticks in transparent frame must be black.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_btn_switch_to_on_mtrl_00001.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_btn_switch_to_on_mtrl_00001.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_btn_switch_to_on_mtrl_00001.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_btn_switch_to_on_mtrl_00001.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_btn_switch_to_on_mtrl_00001.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_btn_switch_to_on_mtrl_00012.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_btn_switch_to_on_mtrl_00012.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_btn_switch_to_on_mtrl_00012.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_btn_switch_to_on_mtrl_00012.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_btn_switch_to_on_mtrl_00012.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_btn_switch_to_on_mtrl_00012.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_menu_hardkey_panel_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_menu_hardkey_panel_mtrl_mult.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_menu_hardkey_panel_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_menu_hardkey_panel_mtrl_mult.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_menu_hardkey_panel_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_menu_hardkey_panel_mtrl_mult.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_popup_background_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-hdpi\abc_popup_background_mtrl_mult.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_popup_background_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-mdpi\abc_popup_background_mtrl_mult.9.png
ERROR: 9-patch image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_popup_background_mtrl_mult.9.png malformed.
ERROR: Failure processing PNG image e:\android1\sdk\support\v7\appcompat\res\drawable-xhdpi\abc_popup_background_mtrl_mult.9.png
e:\android1\sdk\support\v7\appcompat\res\layout\notification_media_cancel_action.xml:18: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/abc_ic_clear_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_borderless_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_default_mtrl_shape').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_borderless_material.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_default_mtrl_shape').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_check_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_check_to_on_mtrl_015').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_check_material.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_check_to_on_mtrl_000').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_colored_material.xml:20: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_default_mtrl_shape').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_radio_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_radio_to_on_mtrl_015').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_btn_radio_material.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_radio_to_on_mtrl_000').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_edit_text_material.xml:24: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_default_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_edit_text_material.xml:25: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_default_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_edit_text_material.xml:26: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_activated_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_dark.xml:20: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_dark.xml:21: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_dark.xml:22: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_dark.xml:23: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_dark.xml:24: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_focused_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_light.xml:20: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_light.xml:21: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_light.xml:22: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_light.xml:23: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_item_background_holo_light.xml:24: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_focused_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_background_transition_holo_dark.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_pressed_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_background_transition_holo_dark.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_longpressed_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_background_transition_holo_light.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_pressed_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_background_transition_holo_light.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_longpressed_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_dark.xml:22: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_dark.xml:23: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_dark.xml:24: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_dark.xml:25: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_dark').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_dark.xml:26: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_focused_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_light.xml:22: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_light.xml:23: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_disabled_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_light.xml:24: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_light.xml:25: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_selector_background_transition_holo_light').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_list_selector_holo_light.xml:26: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_list_focused_holo').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_ratingbar_full_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_rating_star_off_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_ratingbar_full_material.xml:20: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_rating_star_off_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_ratingbar_full_material.xml:22: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_rating_star_on_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_thumb_material.xml:20: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/abc_scrubber_control_off_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_thumb_material.xml:24: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/abc_scrubber_control_off_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_thumb_material.xml:28: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/abc_scrubber_control_to_pressed_mtrl_005').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_thumb_material.xml:32: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/abc_scrubber_control_to_pressed_mtrl_000').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_track_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_scrubber_track_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_track_material.xml:26: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_scrubber_primary_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_seekbar_track_material.xml:36: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_scrubber_primary_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_spinner_textfield_background_material.xml:25: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_default_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_spinner_textfield_background_material.xml:26: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_spinner_mtrl_am_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_spinner_textfield_background_material.xml:31: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_activated_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_spinner_textfield_background_material.xml:32: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_spinner_mtrl_am_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_switch_thumb_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_switch_to_on_mtrl_00012').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_switch_thumb_material.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_btn_switch_to_on_mtrl_00001').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_tab_indicator_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_tab_indicator_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_textfield_search_material.xml:18: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_search_activated_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_textfield_search_material.xml:19: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_search_activated_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_textfield_search_material.xml:20: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_search_default_mtrl_alpha').
e:\android1\sdk\support\v7\appcompat\res\drawable\abc_textfield_search_material.xml:21: error: Error: No resource found that matches the given name (at 'drawable' with value '@drawable/abc_textfield_search_default_mtrl_alpha').
AAPT path: E:\android1\sdkk\tools\..\platform-tools\aapt.exe
Exit code:1Packaging files.    Error
Exit code:1
کسی میدونه مشکل از کجاس؟
هیچکدوم از ریسورس ها رو پیدا نکرده برای شما
باید ادرس ریسورس ها رو درست بدین به برنامه
