میخوام روی تصویر یه فایل با drawtext متنی رو بنویسم ولی خطا میده
یه فایل png رو از dirassest میخونم و با canvas، کار drawtext رو انجام میده و در نهایت توی ایمیج ویو نشون میدم
کدم اینه :
Dim imageview1 As ImageView
imageview1.Initialize("imageview1")
Activity.AddView(imageview1,0,0,100%x,100%y)
Dim btemp As Bitmap=LoadBitmap(File.DirAssets,"index.png")
Dim can As Canvas
can.Initialize2(btemp)
can.DrawText("matne test",10,20, Typeface.DEFAULT_BOLD,20,Colors.Blue,"LEFT")
imageview1.SetBackgroundImage(btemp)
و خطایی که میده هم اینه:
** Service (starter) Create **
** Service (starter) Start **
main_activity_create (java line: 343)
java.lang.RuntimeException: Bitmap is not mutable.
at anywheresoftware.b4a.objects.drawable.CanvasWrapper.Initialize2(CanvasWrapper.java:104)
at b4a.examplegif.main._activity_create(main.java:343)
at java.lang.reflect.Method.invoke(Method.java:525)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169)
at b4a.examplegif.main.afterFirstLayout(main.java:102)
at b4a.examplegif.main.access$000(main.java:17)
at b4a.examplegif.main$WaitForLayout.run(main.java:80)
at android.os.Handler.handleCallback(Handler.java:800)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:194)
at android.app.ActivityThread.main(ActivityThread.java:5455)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:966)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:733)
manoochehr_sh 55
کدم اینه :
Dim imageview1 As ImageView imageview1.Initialize("imageview1") Activity.AddView(imageview1,0,0,100%x,100%y) Dim btemp As Bitmap=LoadBitmap(File.DirAssets,"index.png") Dim can As Canvas can.Initialize2(btemp) can.DrawText("matne test",10,20, Typeface.DEFAULT_BOLD,20,Colors.Blue,"LEFT") imageview1.SetBackgroundImage(btemp)
** Service (starter) Create ** ** Service (starter) Start ** ** Activity (main) Create, isFirst = true ** main_activity_create (java line: 343) java.lang.RuntimeException: Bitmap is not mutable. at anywheresoftware.b4a.objects.drawable.CanvasWrapper.Initialize2(CanvasWrapper.java:104) at b4a.examplegif.main._activity_create(main.java:343) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:525) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169) at b4a.examplegif.main.afterFirstLayout(main.java:102) at b4a.examplegif.main.access$000(main.java:17) at b4a.examplegif.main$WaitForLayout.run(main.java:80) at android.os.Handler.handleCallback(Handler.java:800) at android.os.Handler.dispatchMessage(Handler.java:100) at android.os.Looper.loop(Looper.java:194) at android.app.ActivityThread.main(ActivityThread.java:5455) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:525) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:966) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:733) at dalvik.system.NativeStart.main(Native Method)
