ببخشید هنگام خروجی گرفتن از برنامه ی متریال ارور زیر نمایان می شود
درضمن ادرس دهی ریسورس ها رو هم درست دادم ممنون میشم جواب بدید
B4A version: 5.50
Parsing code. (0.00s)
Compiling code. (0.05s)
Compiling layouts code. (0.01s)
Generating R file. Error
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:75: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:79: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.CloseMode'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:83: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.Overflow'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:25: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabView'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:29: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabView'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:33: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabText'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:37: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:65: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Title'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:69: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Subtitle'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:45: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Menu'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:49: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:53: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:57: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title.Inverse'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:61: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle.Inverse'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:184: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar.Horizontal'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:188: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:113: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:115: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner.Underlined'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:117: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:110: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.DropDownItem.Spinner'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:107: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView.DropDown'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:123: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:128: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListPopupWindow'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:140: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:145: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:131: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.PopupMenu'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:134: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.PopupMenu'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:148: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:152: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:156: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:160: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:166: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Title'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:170: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Subtitle'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:174: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.AutoCompleteTextView'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:93: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Toolbar.Button.Navigation'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:97: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:101: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:62: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:176: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.RatingBar'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:178: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:180: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Small'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:192: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.TextView.SpinnerItem'.
d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:194: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.TextView.SpinnerItem'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:22: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display4'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:24: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display3'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display2'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:28: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display1'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:30: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Headline'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:32: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Title'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:34: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Subhead'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body2'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:38: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body1'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:40: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Caption'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:42: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Menu'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:60: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:46: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Inverse'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:48: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:50: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large.Inverse'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:52: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:54: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium.Inverse'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:56: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small'.
d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:58: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small.Inverse'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:20: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:25: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:24: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:29: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:33: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:37: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:42: error: Error: No resource found that matches the given name: attr 'android:layout_toEndOf'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:41: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:47: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:52: error: Error: No resource found that matches the given name: attr 'android:layout_marginEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:51: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:57: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:56: error: Error: No resource found that matches the given name: attr 'android:paddingStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:61: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:65: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:69: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'.
d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:70: error: Error: No resource found that matches the given name: attr 'android:textAlignment'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:31: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Dialog'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light.Dialog'.
d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:351: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:29: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:358: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:37: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:365: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:45: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:372: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:53: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:202: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:204: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:203: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:217: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Light'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:221: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:220: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:207: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:211: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:210: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:227: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.ActionBar'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:231: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:230: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:234: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark.ActionBar'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:239: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:238: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:81: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:83: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:84: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:82: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:79: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:80: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:118: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:120: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:121: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:119: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:116: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:117: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:155: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:157: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:158: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:156: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:153: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:154: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:192: error: Error: No resource found that matches the given name: attr 'android:colorAccent'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:194: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:195: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:193: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:190: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'.
d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:191: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.
ddddd 1
B4A version: 5.50 Parsing code. (0.00s) Compiling code. (0.05s) Compiling layouts code. (0.01s) Generating R file. Error d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:75: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:79: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.CloseMode'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:83: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionButton.Overflow'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:25: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabView'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:29: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabView'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:33: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ActionBar.TabText'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:37: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.ActionBar.TabText'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:65: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Title'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:69: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionMode.Subtitle'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:45: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Menu'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:49: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:53: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:57: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title.Inverse'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:61: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle.Inverse'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:184: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar.Horizontal'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:188: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ProgressBar'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:113: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:115: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner.Underlined'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:117: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Spinner'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:110: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.DropDownItem.Spinner'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:107: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView.DropDown'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:123: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListView'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:128: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.ListPopupWindow'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:140: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:145: error: Error: No resource found that matches the given name: attr 'android:overlapAnchor'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:131: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.PopupMenu'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:134: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Light.PopupMenu'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:148: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:152: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:156: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Large'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:160: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.PopupMenu.Small'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:166: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Title'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:170: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.SearchResult.Subtitle'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:174: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.AutoCompleteTextView'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:93: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Toolbar.Button.Navigation'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:97: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Title'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:101: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.ActionBar.Subtitle'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:62: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:176: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.RatingBar'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:178: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:180: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.Button.Small'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:192: error: Error retrieving parent for item: No resource found that matches the given name 'android:Widget.Material.TextView.SpinnerItem'. d:\support\support\v7\appcompat\res\values-v21\styles_base.xml:194: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.TextView.SpinnerItem'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:20: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:22: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display4'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:24: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display3'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display2'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:28: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Display1'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:30: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Headline'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:32: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Title'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:34: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Subhead'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body2'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:38: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Body1'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:40: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Caption'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:42: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Menu'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:60: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Button'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:46: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Inverse'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:48: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:50: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Large.Inverse'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:52: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:54: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Medium.Inverse'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:56: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small'. d:\support\support\v7\appcompat\res\values-v21\styles_base_text.xml:58: error: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Small.Inverse'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:20: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:25: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:24: error: Error: No resource found that matches the given name: attr 'android:paddingStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:29: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:33: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:37: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:42: error: Error: No resource found that matches the given name: attr 'android:layout_toEndOf'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:41: error: Error: No resource found that matches the given name: attr 'android:layout_toStartOf'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:47: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:52: error: Error: No resource found that matches the given name: attr 'android:layout_marginEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:51: error: Error: No resource found that matches the given name: attr 'android:paddingStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:57: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:56: error: Error: No resource found that matches the given name: attr 'android:paddingStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:61: error: Error: No resource found that matches the given name: attr 'android:paddingEnd'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:65: error: Error: No resource found that matches the given name: attr 'android:layout_marginStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:69: error: Error: No resource found that matches the given name: attr 'android:layout_alignParentStart'. d:\support\support\v7\appcompat\res\values-v17\styles_rtl.xml:70: error: Error: No resource found that matches the given name: attr 'android:textAlignment'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:26: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:31: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:36: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Dialog'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:41: error: Error retrieving parent for item: No resource found that matches the given name 'android:Theme.Material.Light.Dialog'. d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:351: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:29: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:358: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:37: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:365: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:45: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v11\themes_base.xml:372: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v14\themes_base.xml:53: error: Error: No resource found that matches the given name: attr 'android:actionModeShareDrawable'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:202: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:204: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:203: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:217: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Light'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:221: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:220: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:207: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:211: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:210: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:227: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.ActionBar'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:231: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:230: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:234: error: Error retrieving parent for item: No resource found that matches the given name 'android:ThemeOverlay.Material.Dark.ActionBar'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:239: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:238: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:81: error: Error: No resource found that matches the given name: attr 'android:colorAccent'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:83: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:84: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:82: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:79: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:80: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:118: error: Error: No resource found that matches the given name: attr 'android:colorAccent'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:120: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:121: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:119: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:116: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:117: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:155: error: Error: No resource found that matches the given name: attr 'android:colorAccent'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:157: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:158: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:156: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:153: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:154: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:192: error: Error: No resource found that matches the given name: attr 'android:colorAccent'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:194: error: Error: No resource found that matches the given name: attr 'android:colorControlActivated'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:195: error: Error: No resource found that matches the given name: attr 'android:colorControlHighlight'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:193: error: Error: No resource found that matches the given name: attr 'android:colorControlNormal'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:190: error: Error: No resource found that matches the given name: attr 'android:colorPrimary'. d:\support\support\v7\appcompat\res\values-v21\themes_base.xml:191: error: Error: No resource found that matches the given name: attr 'android:colorPrimaryDark'.لینک ارسال
