sql4.Initialize(File.DirInternal , "uni_chart.db" , True)
curchk = sql4.ExecQuery("select * from biling where name ="&chos)
curchk.Position = 0
Label10.Text = curchk.GetString("khardieh")
If Label10.Text = "no" Then
pardakhtmain.RequestPayment("inappbuy","inapp","pardakhtmain")
Else If Label10.Text = "yes" Then
Spinner2.Visible = True
mosio02 0
سلام دوستان مشکل این کد چیه؟
sql4.Initialize(File.DirInternal , "uni_chart.db" , True) curchk = sql4.ExecQuery("select * from biling where name ="&chos) curchk.Position = 0 Label10.Text = curchk.GetString("khardieh") If Label10.Text = "no" Then pardakhtmain.RequestPayment("inappbuy","inapp","pardakhtmain") Else If Label10.Text = "yes" Then Spinner2.Visible = True End Ifلینک ارسال
