آقا یه سورس متریال دارم میخوام خروجی بگیرم این ارور رو میده :
Generating R file. Error
..\resource\values\themes.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'.
..\resource\values\themes.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'.
..\resource\values\themes.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'.
..\resource\values-v22\themes.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'.
..\resource\values-v22\themes.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'.
..\resource\values-v22\themes.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'.
lvlaHcli 0
Generating R file. Error ..\resource\values\themes.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'. ..\resource\values\themes.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'. ..\resource\values\themes.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'. ..\resource\values-v22\themes.xml:6: error: Error: No resource found that matches the given name: attr 'colorAccent'. ..\resource\values-v22\themes.xml:4: error: Error: No resource found that matches the given name: attr 'colorPrimary'. ..\resource\values-v22\themes.xml:5: error: Error: No resource found that matches the given name: attr 'colorPrimaryDark'.این پوشه ی ریسورس هم توی پوشه ی برنامه هست
کسی میدونه برا چی ارور میده ؟
