من واسه نرم افزارم از کتابخانه فراخوانی استفاده کردم و خواستم متن رو زیر عکس قرار بدم ولی وقتی فراخوان میشه از دیتابیس، کلا به هم میریزه وعکس روی متن قرار میگیره و اسکرول نمیشه
اینم هم کد ها واسه راهنمایی دوستان :
Private btnbk As Button
Private lbltot As Label
Private sct As ScrollView
Dim fo As Typeface
Dim mt As Farakhani
Dim sql1 As SQL
Dim cur As Cursor
Dim ts As TextSetting
Dim l1 As Label
Dim a1 As ImageView
Dim bt1 As Bitmap
Dim a2 As ImageView
Dim bt2 As Bitmap
Activity.LoadLayout("tot")
fo = Typeface.LoadFromAssets("font.TTF")
btnbk.Typeface = fo
lbltot.Typeface = fo
tm1.Initialize("tm1",1200)
mt.IsInitialized
ts.Initialize
l1.Initialize("")
a1.Initialize("a1")
a2.Initialize("a2")
mt.FarakhaniMatn("leica.db",sql1,cur,"SELECT * FROM main Where id=","1",l1,"m&a")
sct.Panel.AddView(l1,20,25,90%x,100%y)
ts.LongText(l1,l1.Text,18,sct,1.5)
l1.Typeface = fo
l1.TextColor = Colors.Black
mt.FarakhaniImage("leica.db", sql1,cur,"SELECT * FROM main Where id=","2","m&a",bt1)
a1.Bitmap = bt1
sct.Panel.AddView(a1,40,50,90%x,100%y)
mt.FarakhaniImage("leica.db",sql1,cur,"SELECT * FROM main Where id=","3","m&a",bt2)
a2.Bitmap = bt2
sct.Panel.AddView(a2,60,75,90%x,100%y)
محمد معین عبدی 255
سلان خدمت دوستان عزیز
Sub Globals Private btnbk As Button Private lbltot As Label Private sct As ScrollView Dim fo As Typeface Dim mt As Farakhani Dim sql1 As SQL Dim cur As Cursor Dim ts As TextSetting Dim l1 As Label Dim a1 As ImageView Dim bt1 As Bitmap Dim a2 As ImageView Dim bt2 As Bitmap End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("tot") fo = Typeface.LoadFromAssets("font.TTF") btnbk.Typeface = fo lbltot.Typeface = fo tm1.Initialize("tm1",1200) mt.IsInitialized ts.Initialize l1.Initialize("") a1.Initialize("a1") a2.Initialize("a2") mt.FarakhaniMatn("leica.db",sql1,cur,"SELECT * FROM main Where id=","1",l1,"m&a") sct.Panel.AddView(l1,20,25,90%x,100%y) ts.LongText(l1,l1.Text,18,sct,1.5) l1.Typeface = fo l1.TextColor = Colors.Black mt.FarakhaniImage("leica.db", sql1,cur,"SELECT * FROM main Where id=","2","m&a",bt1) a1.Bitmap = bt1 sct.Panel.AddView(a1,40,50,90%x,100%y) mt.FarakhaniImage("leica.db",sql1,cur,"SELECT * FROM main Where id=","3","m&a",bt2) a2.Bitmap = bt2 sct.Panel.AddView(a2,60,75,90%x,100%y) End Subعکس از برنامه :
http://s9.picofile.com/file/8267773292/Screenshot_۲۰۱۶۰۹۱۸_۰۹۲۳۲۹.png
دوستان لطفا راهنمایی کنید.
