مشکل در هنگام کامپایل گرفتن
Payandehamir
سلام دوستان موقع کامپایل گرفتن  به این مشکل برمی خورم می خواستم ببیم مشکل از چیه؟؟؟؟؟؟؟؟؟؟؟
B4A version: 6.00 BETA #1
Parsing code.    (0.02s)
Compiling code.    (0.14s)
Compiling layouts code.    (0.00s)
Generating R file.    (1.83s)
Compiling generated Java code.    (1.81s)
Convert byte code - optimized dex.    Error
UNEXPECTED TOP-LEVEL EXCEPTION:
java.lang.IllegalArgumentException: already added: Landroid/support/v7/text/AllCapsTransformationMethod;
	at com.android.dx.dex.file.ClassDefsSection.add(ClassDefsSection.java:122)
	at com.android.dx.dex.file.DexFile.add(DexFile.java:161)
	at com.android.dx.command.dexer.Main.processClass(Main.java:615)
	at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570)
	at com.android.dx.command.dexer.Main.access$2(Main.java:546)
	at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514)
	at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284)
	at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
	at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
	at com.android.dx.command.dexer.Main.processOne(Main.java:537)
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236)
	at com.android.dx.command.dexer.Main.run(Main.java:206)
	at com.android.dx.command.dexer.Main.main(Main.java:179)
	at com.android.dx.command.Main.main(Main.java:103)
1 error; aborting
