در 2 ساعت قبل، crypt3r گفته است :
سلام این ارور از چیست
اینم ورژن کتابخونه ها
api 24
java 1.7
سلام عزیز
من اروری نمیبینم:fekr:
در ۱ ساعت قبل، Shayan Shojaei گفته است :
سلام عزیز
ببخشید بفرمایید ارور روی دیباگ
LogCat connected to: 192.168.56.101:5555
--------- beginning of /dev/log/system
--------- beginning of /dev/log/main
Copying updated assets files (4)
** Activity (main) Resume **
Error occurred on line: 33 (Main)
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
	at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:166)
	at anywheresoftware.b4a.objects.ActivityWrapper.LoadLayout(ActivityWrapper.java:209)
	at java.lang.reflect.Method.invoke(Method.java:511)
	at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:708)
	at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:340)
	at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:247)
	at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:134)
	at ir.shayan.smttp.main.afterFirstLayout(main.java:102)
	at ir.shayan.smttp.main.access$000(main.java:17)
	at ir.shayan.smttp.main$WaitForLayout.run(main.java:80)
	at android.os.Handler.handleCallback(Handler.java:615)
	at android.os.Handler.dispatchMessage(Handler.java:92)
	at android.os.Looper.loop(Looper.java:137)
	at android.app.ActivityThread.main(ActivityThread.java:4745)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
Caused by: java.lang.reflect.InvocationTargetException
	at anywheresoftware.b4a.objects.CustomViewWrapper.AfterDesignerScript(CustomViewWrapper.java:64)
	at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:158)
	... 21 more
Caused by: android.content.res.Resources$NotFoundException: File res/drawable/abc_ic_ab_back_material.xml from drawable resource ID #0x7f020013
	at android.content.res.Resources.loadDrawable(Resources.java:1918)
	at android.content.res.Resources.getDrawable(Resources.java:659)
	at android.support.v4.content.ContextCompat.getDrawable(ContextCompat.java:354)
	at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:187)
	at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:175)
	at android.support.v7.widget.TintTypedArray.getDrawable(TintTypedArray.java:66)
	at android.support.v7.widget.Toolbar.<init>(Toolbar.java:295)
	at android.support.v7.widget.Toolbar.<init>(Toolbar.java:226)
	at android.support.v7.widget.Toolbar.<init>(Toolbar.java:222)
	at de.amberhome.objects.appcompat.ACToolbarDarkWrapper.innerInitialize(ACToolbarDarkWrapper.java:25)
	at anywheresoftware.b4a.objects.ViewWrapper.Initialize(ViewWrapper.java:65)
	at de.amberhome.objects.appcompat.ACToolBarWrapper.Initialize(ACToolBarWrapper.java:62)
	at de.amberhome.objects.appcompat.ACToolBarWrapper._initialize(ACToolBarWrapper.java:129)
	... 25 more
Caused by: org.xmlpull.v1.XmlPullParserException: Binary XML file line #17: invalid drawable tag vector
	at android.graphics.drawable.Drawable.createFromXmlInner(Drawable.java:877)
	at android.graphics.drawable.Drawable.createFromXml(Drawable.java:818)
	at android.content.res.Resources.loadDrawable(Resources.java:1915)
	... 37 more
در 41 دقیقه قبل، crypt3r گفته است :
	... 21 more
	... 25 more
	... 37 more
ببینین مشکل از کتابخونه نیست
مشکل از فایل هایی هست که برای اجرای اپ کامپت نیاز دارین
بنظرم یه پروژه جدید بسازین اگر میخواین تست کنین و یک ویو بزارین و روی اون تست کنین :)
در ۱ ساعت قبل، crypt3r گفته است :
تست کردم ارور میده باز
رو پروژه جدید تست کردین؟
کد ها درسته؟
چه اروری میده؟
همین ارور رو میده
شما بی زحمت از همین پروژه یه گیف شات بده اصلا فکر نکنم پروژه شما هم تو سیستمتون کار کنه من همه چیزم ورژن فوله
در 18 ساعت قبل، crypt3r گفته است :
همین ارور رو میده
عزیز apk گذاشتم :|
ران شده یعنی ...
در 20 دقیقه قبل، crypt3r گفته است :
upppppppppppppppppppppppppppppppppppppp
من تست کردم و استفاده کردم بدون هیچ مشکلی کار میکنه
در در 1395/07/04, 18:49:44، crypt3r گفته است :
خوب apk بدید منم تست کنم یا شات گیف بزارید
یه ذره دقت کنید راحت می تونید لینک دانلود رو پیدا کنید
توی پست اول روی "مشاهده فایل" بزنید
  • 1 ماه بعد...
ایا لینک مشکل داره من وقتی دانلود می کنم وقتی بازش می کنم این ارور میده
در ۱ ساعت قبل، vahid1363 گفته است :
سلام فایل rar ایراد داره
لطفا برسی کنید
در در 1395/08/20, 10:12:19، ali afrazi گفته است :
دوستان فایل رو همین الآن چک کردم
کاملا سالم بود
در 6 دقیقه قبل، vahid1363 گفته است :
آقا درست نیست
من چندین بار دیشب و امروز دانلود کردم
فایل خرابه
مجددا آپلود کنید
عزیز من فایل رو دانلود کردم
تست کردم به درستی Extract شد
احتمالا مشکل از WinRAR شما هست... طبیعی هستش که بعضی موقع ها WinRAR خطا بده
شما از طریق خود WinRAR فایل رو Repair کنید درست میشه و میتونید خروجی بگیرید...
من خودم فایل رو دوباره براتون زیپ کردم و آپلود کردم... این رو تست کنید:
دانلود
ارسال پاسخ به این موضوع ...
