مشل من اینه وقتی فایل دانلود میشه موقع خروج سرویسstop HttpUtils2Service میکنم موقع (دانلود اسم دکمش dw هست) همون سرویس رو start میکنم ولی ارور میده
توی حالت release:میگه آبجکت باید اینیشیالایز شه
توی حالت debug :
خط خاصی رو نشون نمیده
و اینو مینویسه
java.lang.RuntimeException: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:206)
at anywheresoftware.b4a.BA$2.run(BA.java:328)
at android.os.Handler.handleCallback(Handler.java:743)
at android.os.Looper.loop(Looper.java:150)
at android.app.ActivityThread.main(ActivityThread.java:5546)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:792)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:682)
Caused by: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference
at anywheresoftware.b4a.samples.httputils2.httputils2service._completejob(httputils2service.java:99)
at anywheresoftware.b4a.samples.httputils2.httputils2service._response_streamfinish(httputils2service.java:152)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169)
... 8 more
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: false
#End Region
Dim hj As HttpJob
Dim lbl As Label
Dim lpic As Label
Dim awake As PhoneWakeState
Dim link,name,dier As String
Dim mediaplayer1 As MediaPlayer
Dim lname As Label
Dim lurl As Label
Dim fara As Farakhani
' Private As Button
' Private As Button
Dim l As Label
' Dim cafe As Intent
Dim ts As TextSetting
Private dw As Button
Private st As Button
Private pu As Button
Private pl As Button
Private imageview1 As ImageView
Private pl2 As Button
Dim m2 As m2Lib
Dim no As Notification
Dim tite2 As String
Dim tite1 As Label
Private Label1 As Label
Dim h As Int
Activity.LoadLayout("download")
File.MakeDir(File.DirRootExternal, "kodack")
tite1.Initialize("")
lname.Initialize("")
lurl.Initialize("")
dw.Visible=True
pl.Visible=False
pu.Visible=False
st.Visible=False
pl2.Visible=False
h=0
lbl.Initialize("")
l.Initialize("")
lpic.Initialize("")
ts.Initialize
lbl.TextColor=Colors.Black
lbl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
Label1.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
dw.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pu.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
st.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pl2.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
If(File.Exists(File.DirRootExternal,"c.txt")) Then
Dim str As String
str = File.readString(File.DirRootExternal,"c"&".txt")
If str = "Colors.Black" Then
lbl.textColor = Colors.Black
Else If str = "Colors.Red" Then
lbl.textColor = Colors.Red
Else If str = "Colors.Blue" Then
lbl.textColor = Colors.Blue
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,tite1,"titr")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lbl,"matn")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lname,"name")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lurl,"url")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lpic,"pic2")
tite2=tite1.Text
' lbl.Textsize=File.GetText(File.DirRootExternal,"textsize"&".txt")
' l.Text=File.GetText(File.DirRootExternal,"textsize"&".txt")
imageview1.SetBackgroundImage(LoadBitmap(File.DirAssets,lpic.Text))
imageview1.Height=m2.GetPicHeight(imageview1)
imageview1.Width=m2.GetPicWidth(imageview1)
If(File.Exists(File.DirRootExternal & "/kodack", lname.Text)) Then
ToastMessageShow("نیازی به دانلود نیست", True)
mediaplayer1.Initialize2("mediaplayer1")
mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.Text)
mediaplayer1.Looping=False
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
Label1.Visible=False
If(File.Exists(File.DirRootExternal,"s.txt")) Then
Main.cur.Position = 0
ScrollView1.Panel.AddView(lbl,0,0,75.5%x,100%y)
ts.LongText(lbl,lbl.Text,File.GetText(File.DirRootExternal,"s"&".txt"),ScrollView1,1.5)
ts.LongText(lbl,lbl.Text,18,ScrollView1,1.5)
lbl.Gravity=Gravity.RIGHT
awake.KeepAlive(True)
Sub JobDone(Job As HttpJob)
Try
If Job.Success = True Then
Select Case Job.JobName
Case "job1"
Dim o As OutputStream
o = File.OpenOutput(dier, name, False)
File.Copy2(Job.GetInputStream, o)
o.Close
Job.Release
Case "job2"
o.Close
Job.Release
ToastMessageShow("دانلود شد!",True)
h=0
Case "job3"
o.Close
Job.Release
h=0
dw.Visible=False
pl.Visible=False
pl2.Visible=True
End Select
h=0
Msgbox("اول باید به یه اینترنت سریع وصل شی...","ببخشید!!!")
dw.Visible=True
pl.Visible=False
pl2.Visible=False
ProgressDialogHide
Catch
File.Delete(File.DirRootExternal & "/kodack", lname.Text)
dw.Visible=True
pl.Visible=False
pl2.Visible=False
Dim r As Int
r = Msgbox2("خطایی رخ داده...","","لغو","","دوباره",LoadBitmap(File.DirAssets,"icon.png"))
If ( r = DialogResponse.POSITIVE) Then
Activity.Finish
h=0
If ( r = DialogResponse.NEGATIVE) Then
dw.Visible=True
pl.Visible=False
name=lname.Text
dier=File.DirRootExternal& "/kodack"
link=lurl.Text
hj.Initialize("job3",Me)
hj.Download(link)
h=1
Label1.Visible=True
dw.Visible=False
End Try
StopService(HttpUtils2Service)
Sub dw_Click
StartService(HttpUtils2Service)
dw.Visible=True
pl.Visible=False
h=1
name=lname.Text
link=lurl.Text
hj.Download(link)
Label1.Visible=True
dw.Visible=False
Sub pl_click
mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.text)
mediaplayer1.Play
dw.Visible=False
pl.Visible=False
pu.Visible=True
st.Visible=True
pl2.Visible=False
h=2
no.Initialize
no.Icon="icon"
no.Light=True
no.Vibrate = False
no.sound = False
no.AutoCancel=False
no.OnGoingEvent=True
no.SetInfo("درحال پخش...",tite2,Null)
no.AutoCancel=True
no.Cancel(1)
no.Notify(1)
Sub pu_click
mediaplayer1.Pause
dw.Visible=False
pl.Visible=False
pu.Visible=False
st.Visible=True
pl2.Visible=True
h=0
no.Cancel(1)
Sub st_click
mediaplayer1.Stop
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
h=0
no.Cancel(1)
Sub pl2_click
mediaplayer1.Play
dw.Visible=False
pl.Visible=False
pu.Visible=True
st.Visible=True
pl2.Visible=False
h=2
no.Initialize
no.Icon="icon"
no.Light=True
no.Vibrate = False
no.sound = False
no.AutoCancel=True
no.AutoCancel=True
no.Notify(1)
Sub mediaplayer1_Complete
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
h=0
no.Cancel(1)
Sub Activity_Resume
'Sub ImageView7_Click
' cafe.Initialize(cafe.ACTION_EDIT,"bazaar://details?id=com.sorod.pack")
' StartActivity(cafe)
'End Sub
'Sub CreateUri(uri As String) As Object
' Dim r As Reflector
' Return r.RunStaticMethod("android.net.Uri", "parse", Array As Object(uri), Array As String("java.lang.String"))
'End Sub
If h=1 Then
Dim r As Int
r = Msgbox2("دانلود لغو شه؟","","آره","","نه",LoadBitmap(File.DirAssets,"icon.png"))
Activity.Finish
Return True
Return True
نکته:من 18 تا module ساختم و اگه از سورس largfiledownload استفاده کنم خیلی وقت میبره.
نکته:وقتی دانلود رو لغو میکنم و دوباره برمیگردم که دانلود کنم این ارور رو میده
نکته:وقتی بعد ارور برمیگردم قسمت قبلی یه لیست ویو دارم که از دیتابیس متناشو فراخوانی میکنه که کاملا سفید میشه
توجه:من فقط میخوام دانلودم لغو شه اگه سرویسم متوقف نشد مهم نیست
reza644 435
توی حالت debug :
و اینو مینویسه
java.lang.RuntimeException: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference at anywheresoftware.b4a.BA.raiseEvent2(BA.java:206) at anywheresoftware.b4a.BA$2.run(BA.java:328) at android.os.Handler.handleCallback(Handler.java:743) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:150) at android.app.ActivityThread.main(ActivityThread.java:5546) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:792) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:682) Caused by: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference at anywheresoftware.b4a.samples.httputils2.httputils2service._completejob(httputils2service.java:99) at anywheresoftware.b4a.samples.httputils2.httputils2service._response_streamfinish(httputils2service.java:152) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169) ... 8 more#Region Activity Attributes #FullScreen: False #IncludeTitle: false #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim hj As HttpJob End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim lbl As Label Dim lpic As Label Dim awake As PhoneWakeState Dim link,name,dier As String Dim mediaplayer1 As MediaPlayer Dim lname As Label Dim lurl As Label Dim fara As Farakhani Private ScrollView1 As ScrollView ' Private As Button ' Private As Button Dim l As Label ' Dim cafe As Intent Dim ts As TextSetting Private dw As Button Private st As Button Private pu As Button Private pl As Button Private imageview1 As ImageView Private pl2 As Button Dim m2 As m2Lib Dim no As Notification Dim tite2 As String Dim tite1 As Label Private Label1 As Label Dim h As Int End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("download") File.MakeDir(File.DirRootExternal, "kodack") tite1.Initialize("") lname.Initialize("") lurl.Initialize("") dw.Visible=True pl.Visible=False pu.Visible=False st.Visible=False pl2.Visible=False h=0 lbl.Initialize("") l.Initialize("") lpic.Initialize("") ts.Initialize lbl.TextColor=Colors.Black lbl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") Label1.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") dw.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") pl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") pu.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") st.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") pl2.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf") If(File.Exists(File.DirRootExternal,"c.txt")) Then Dim str As String str = File.readString(File.DirRootExternal,"c"&".txt") If str = "Colors.Black" Then lbl.textColor = Colors.Black Else If str = "Colors.Red" Then lbl.textColor = Colors.Red Else If str = "Colors.Blue" Then lbl.textColor = Colors.Blue End If Else lbl.textColor = Colors.Black End If fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,tite1,"titr") fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lbl,"matn") fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lname,"name") fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lurl,"url") fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lpic,"pic2") tite2=tite1.Text ' lbl.Textsize=File.GetText(File.DirRootExternal,"textsize"&".txt") ' l.Text=File.GetText(File.DirRootExternal,"textsize"&".txt") imageview1.SetBackgroundImage(LoadBitmap(File.DirAssets,lpic.Text)) imageview1.Height=m2.GetPicHeight(imageview1) imageview1.Width=m2.GetPicWidth(imageview1) If(File.Exists(File.DirRootExternal & "/kodack", lname.Text)) Then ToastMessageShow("نیازی به دانلود نیست", True) mediaplayer1.Initialize2("mediaplayer1") mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.Text) mediaplayer1.Looping=False dw.Visible=False pl.Visible=True pu.Visible=False st.Visible=True pl2.Visible=False Label1.Visible=False Else Label1.Visible=False End If If(File.Exists(File.DirRootExternal,"s.txt")) Then ' lbl.Textsize=File.GetText(File.DirRootExternal,"textsize"&".txt") ' l.Text=File.GetText(File.DirRootExternal,"textsize"&".txt") Main.cur.Position = 0 ScrollView1.Panel.AddView(lbl,0,0,75.5%x,100%y) ts.LongText(lbl,lbl.Text,File.GetText(File.DirRootExternal,"s"&".txt"),ScrollView1,1.5) Else ScrollView1.Panel.AddView(lbl,0,0,75.5%x,100%y) ts.LongText(lbl,lbl.Text,18,ScrollView1,1.5) End If lbl.Gravity=Gravity.RIGHT mediaplayer1.Initialize2("mediaplayer1") awake.KeepAlive(True) End Sub Sub JobDone(Job As HttpJob) Try If Job.Success = True Then Select Case Job.JobName Case "job1" Dim o As OutputStream o = File.OpenOutput(dier, name, False) File.Copy2(Job.GetInputStream, o) o.Close Job.Release Case "job2" Dim o As OutputStream o = File.OpenOutput(dier, name, False) File.Copy2(Job.GetInputStream, o) o.Close Job.Release ToastMessageShow("دانلود شد!",True) Label1.Visible=False h=0 Case "job3" Dim o As OutputStream o = File.OpenOutput(dier, name, False) File.Copy2(Job.GetInputStream, o) o.Close Job.Release h=0 ToastMessageShow("دانلود شد!",True) Label1.Visible=False dw.Visible=False pl.Visible=False pl2.Visible=True End Select Else h=0 Msgbox("اول باید به یه اینترنت سریع وصل شی...","ببخشید!!!") dw.Visible=True pl.Visible=False pl2.Visible=False Label1.Visible=False End If ProgressDialogHide Catch If(File.Exists(File.DirRootExternal & "/kodack", lname.Text)) Then File.Delete(File.DirRootExternal & "/kodack", lname.Text) End If dw.Visible=True pl.Visible=False pl2.Visible=False Label1.Visible=False Dim r As Int r = Msgbox2("خطایی رخ داده...","","لغو","","دوباره",LoadBitmap(File.DirAssets,"icon.png")) If ( r = DialogResponse.POSITIVE) Then Activity.Finish h=0 End If If ( r = DialogResponse.NEGATIVE) Then dw.Visible=True pl.Visible=False name=lname.Text dier=File.DirRootExternal& "/kodack" link=lurl.Text hj.Initialize("job3",Me) hj.Download(link) h=1 Label1.Visible=True dw.Visible=False End If End Try End Sub Sub Activity_Pause (UserClosed As Boolean) StopService(HttpUtils2Service) End Sub Sub dw_Click StartService(HttpUtils2Service) dw.Visible=True pl.Visible=False h=1 name=lname.Text dier=File.DirRootExternal& "/kodack" link=lurl.Text hj.Initialize("job3",Me) hj.Download(link) Label1.Visible=True dw.Visible=False End Sub Sub pl_click mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.text) mediaplayer1.Play dw.Visible=False pl.Visible=False pu.Visible=True st.Visible=True pl2.Visible=False h=2 no.Initialize no.Icon="icon" no.Light=True no.Vibrate = False no.sound = False no.AutoCancel=False no.OnGoingEvent=True no.SetInfo("درحال پخش...",tite2,Null) no.AutoCancel=True no.Cancel(1) no.Notify(1) End Sub Sub pu_click mediaplayer1.Pause dw.Visible=False pl.Visible=False pu.Visible=False st.Visible=True pl2.Visible=True h=0 no.Cancel(1) End Sub Sub st_click mediaplayer1.Stop dw.Visible=False pl.Visible=True pu.Visible=False st.Visible=True pl2.Visible=False h=0 no.Cancel(1) End Sub Sub pl2_click mediaplayer1.Play dw.Visible=False pl.Visible=False pu.Visible=True st.Visible=True pl2.Visible=False h=2 no.Initialize no.Icon="icon" no.Light=True no.Vibrate = False no.sound = False no.AutoCancel=True no.OnGoingEvent=True no.SetInfo("درحال پخش...",tite2,Null) no.AutoCancel=True no.Notify(1) End Sub Sub mediaplayer1_Complete dw.Visible=False pl.Visible=True pu.Visible=False st.Visible=True pl2.Visible=False h=0 no.Cancel(1) End Sub Sub Activity_Resume End Sub 'Sub ImageView7_Click ' cafe.Initialize(cafe.ACTION_EDIT,"bazaar://details?id=com.sorod.pack") ' StartActivity(cafe) 'End Sub 'Sub CreateUri(uri As String) As Object ' Dim r As Reflector ' Return r.RunStaticMethod("android.net.Uri", "parse", Array As Object(uri), Array As String("java.lang.String")) 'End Sub Sub Activity_KeyPress (KeyCode As Int) As Boolean If h=1 Then If KeyCode = KeyCodes.KEYCODE_BACK Then Dim r As Int r = Msgbox2("دانلود لغو شه؟","","آره","","نه",LoadBitmap(File.DirAssets,"icon.png")) If ( r = DialogResponse.POSITIVE) Then StopService(HttpUtils2Service) Activity.Finish End If If KeyCode = KeyCodes.KEYCODE_BACK Then Return True End If If ( r = DialogResponse.NEGATIVE) Then Return True End If End If End If End Subنکته:من 18 تا module ساختم و اگه از سورس largfiledownload استفاده کنم خیلی وقت میبره.
