لغو دانلود
reza644
مشل من اینه وقتی فایل دانلود میشه موقع خروج سرویسstop HttpUtils2Service  میکنم موقع (دانلود اسم دکمش dw هست) همون سرویس رو start میکنم ولی ارور میده
توی حالت release:میگه آبجکت باید اینیشیالایز شه
توی حالت debug :
خط خاصی رو نشون نمیده
و اینو مینویسه
java.lang.RuntimeException: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:206)
	at anywheresoftware.b4a.BA$2.run(BA.java:328)
	at android.os.Handler.handleCallback(Handler.java:743)
	at android.os.Looper.loop(Looper.java:150)
	at android.app.ActivityThread.main(ActivityThread.java:5546)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:792)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:682)
Caused by: java.lang.NullPointerException: Attempt to write to field 'boolean anywheresoftware.b4a.samples.httputils2.httpjob._success' on a null object reference
	at anywheresoftware.b4a.samples.httputils2.httputils2service._completejob(httputils2service.java:99)
	at anywheresoftware.b4a.samples.httputils2.httputils2service._response_streamfinish(httputils2service.java:152)
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169)
	... 8 more
#Region  Activity Attributes
    #FullScreen: False
    #IncludeTitle: false
#End Region
Sub Process_Globals
Dim hj As HttpJob
Dim lbl As Label
Dim lpic As Label
Dim awake As PhoneWakeState
    Dim link,name,dier As String
    Dim mediaplayer1 As MediaPlayer
	Dim lname As Label
	Dim lurl As Label
Dim fara As Farakhani
'	Private  As Button
'	Private  As Button
	Dim l As Label
'	Dim cafe As Intent
	Dim ts As TextSetting
	Private dw As Button
	Private st As Button
	Private pu As Button
	Private pl As Button
	Private imageview1 As ImageView
	Private pl2 As Button
	Dim m2 As m2Lib
		Dim no As Notification
	Dim tite2 As String
	Dim tite1 As Label
	Private Label1 As Label
	Dim h As Int
    Activity.LoadLayout("download")
File.MakeDir(File.DirRootExternal, "kodack")
tite1.Initialize("")
lname.Initialize("")
lurl.Initialize("")
dw.Visible=True
pl.Visible=False
pu.Visible=False
st.Visible=False
pl2.Visible=False
h=0
lbl.Initialize("")
l.Initialize("")
lpic.Initialize("")
ts.Initialize
lbl.TextColor=Colors.Black
lbl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
Label1.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
dw.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pl.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pu.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
st.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
pl2.Typeface=Typeface.LoadFromAssets("Far_KoodkBd.ttf")
	If(File.Exists(File.DirRootExternal,"c.txt")) Then
	Dim str As String
str = File.readString(File.DirRootExternal,"c"&".txt")
If str = "Colors.Black" Then
lbl.textColor = Colors.Black
Else If str = "Colors.Red" Then
lbl.textColor = Colors.Red
Else If str = "Colors.Blue" Then
lbl.textColor = Colors.Blue
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,tite1,"titr")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lbl,"matn")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lname,"name")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lurl,"url")
fara.FarakhaniMatn("kodack.db",Main.sql1,Main.cur,"SELECT * FROM ghese1 where id=",ghese.meghdar,lpic,"pic2")
tite2=tite1.Text
'		lbl.Textsize=File.GetText(File.DirRootExternal,"textsize"&".txt")
'		l.Text=File.GetText(File.DirRootExternal,"textsize"&".txt")
	imageview1.SetBackgroundImage(LoadBitmap(File.DirAssets,lpic.Text))
	imageview1.Height=m2.GetPicHeight(imageview1)
	imageview1.Width=m2.GetPicWidth(imageview1)
			If(File.Exists(File.DirRootExternal & "/kodack", lname.Text)) Then
	 ToastMessageShow("نیازی به دانلود نیست",  True)
	mediaplayer1.Initialize2("mediaplayer1")
mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.Text)
    mediaplayer1.Looping=False
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
Label1.Visible=False
			If(File.Exists(File.DirRootExternal,"s.txt")) Then
		Main.cur.Position = 0
ScrollView1.Panel.AddView(lbl,0,0,75.5%x,100%y)
ts.LongText(lbl,lbl.Text,File.GetText(File.DirRootExternal,"s"&".txt"),ScrollView1,1.5)
ts.LongText(lbl,lbl.Text,18,ScrollView1,1.5)
	lbl.Gravity=Gravity.RIGHT
awake.KeepAlive(True)
Sub JobDone(Job As HttpJob)
	Try
If Job.Success = True Then
Select Case Job.JobName
  Case "job1"
  Dim o As OutputStream
  o = File.OpenOutput(dier, name, False)
    File.Copy2(Job.GetInputStream, o)
    o.Close
    Job.Release
    Case "job2"
    o.Close
    Job.Release
    ToastMessageShow("دانلود شد!",True)
h=0
    Case "job3"
    o.Close
    Job.Release
h=0
dw.Visible=False
pl.Visible=False
pl2.Visible=True
 End Select
 h=0
Msgbox("اول باید به یه اینترنت سریع وصل شی...","ببخشید!!!")
dw.Visible=True
pl.Visible=False
pl2.Visible=False
ProgressDialogHide
Catch
	File.Delete(File.DirRootExternal & "/kodack", lname.Text)
dw.Visible=True
pl.Visible=False
pl2.Visible=False
 Dim r As Int
    r = Msgbox2("خطایی رخ داده...","","لغو","","دوباره",LoadBitmap(File.DirAssets,"icon.png"))
    If ( r = DialogResponse.POSITIVE) Then
   Activity.Finish
 h=0
    If ( r = DialogResponse.NEGATIVE) Then
dw.Visible=True
pl.Visible=False
name=lname.Text
dier=File.DirRootExternal& "/kodack"
link=lurl.Text
hj.Initialize("job3",Me)
hj.Download(link)
 h=1
Label1.Visible=True
dw.Visible=False
	End Try
StopService(HttpUtils2Service)
Sub dw_Click
StartService(HttpUtils2Service)
dw.Visible=True
pl.Visible=False
h=1
name=lname.Text
link=lurl.Text
hj.Download(link)
Label1.Visible=True
dw.Visible=False
Sub pl_click
mediaplayer1.Load(File.DirRootExternal & "/kodack", lname.text)
mediaplayer1.Play
dw.Visible=False
pl.Visible=False
pu.Visible=True
st.Visible=True
pl2.Visible=False
h=2
no.Initialize
no.Icon="icon"
no.Light=True
no.Vibrate = False
no.sound = False
no.AutoCancel=False
no.OnGoingEvent=True
no.SetInfo("درحال پخش...",tite2,Null)
no.AutoCancel=True
no.Cancel(1)
no.Notify(1)
Sub pu_click
mediaplayer1.Pause
dw.Visible=False
pl.Visible=False
pu.Visible=False
st.Visible=True
pl2.Visible=True
h=0
no.Cancel(1)
Sub st_click
mediaplayer1.Stop
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
h=0
no.Cancel(1)
Sub pl2_click
mediaplayer1.Play
dw.Visible=False
pl.Visible=False
pu.Visible=True
st.Visible=True
pl2.Visible=False
h=2
no.Initialize
no.Icon="icon"
no.Light=True
no.Vibrate = False
no.sound = False
no.AutoCancel=True
no.AutoCancel=True
no.Notify(1)
Sub mediaplayer1_Complete
dw.Visible=False
pl.Visible=True
pu.Visible=False
st.Visible=True
pl2.Visible=False
h=0
no.Cancel(1)
Sub Activity_Resume
'Sub ImageView7_Click
'	cafe.Initialize(cafe.ACTION_EDIT,"bazaar://details?id=com.sorod.pack")
'	StartActivity(cafe)
'End Sub
'Sub CreateUri(uri As String) As Object
'   Dim r As Reflector
'   Return r.RunStaticMethod("android.net.Uri", "parse", Array As Object(uri), Array As String("java.lang.String"))
'End Sub
Sub Activity_KeyPress (KeyCode As Int) As Boolean
	If h=1 Then
 Dim r As Int
    r = Msgbox2("دانلود لغو شه؟","","آره","","نه",LoadBitmap(File.DirAssets,"icon.png"))
	Activity.Finish
Return True
Return True
نکته:من 18 تا module ساختم و اگه از سورس largfiledownload استفاده کنم خیلی وقت میبره.
نکته:وقتی دانلود رو لغو میکنم و دوباره برمیگردم که دانلود کنم این ارور رو میده
نکته:وقتی بعد ارور برمیگردم قسمت قبلی یه لیست ویو دارم که از دیتابیس متناشو فراخوانی میکنه که کاملا سفید میشه
توجه:من فقط میخوام دانلودم لغو شه اگه سرویسم متوقف نشد مهم نیست
